Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Buying a Code Scanner
Old Jan 12, 2013 | 02:46 PM
spiggy769's Avatar
spiggy769
Hey Guys, I am looking in investing in a Code Scanner. Not looking to pay Snap On Prices but figure I have a limit of around $250, and would like the scanner to be OBD2 and Mode 6 Compatable. Any suggestions?
Old Jan 13, 2013 | 12:10 AM
Jaydoubleyou's Avatar
Jaydoubleyou
I'm not sure what mode 6 data is but I recently picked up a scanner from amazon for about 50 bucks. It does everything I need, such as retrieving codes and getting real time readings from sensors. I have been looking up reviews and haven't really found anything negative about it.
Old Jan 13, 2013 | 12:30 AM
ford2go's Avatar
ford2go
This can be tricky. I have an equus scanner that cost about $180 -- it does SOMETHING that I guess is mode 6.
Thing is, they don't seem to call it that. In my case, it's called something odd (can't remember what right now). They seem to love to make it hard to figure out.
Also, the data is not easy to interpret. It gives a test id and some numerical info plus an indication of out of limits. however, there's no info on what's being reported.
This is for a mopar, and I THINK that I know what I'm seeing from stuff I've seen on the web, but I'm not real sure . Mopar doesn't seem to be forthcoming with the data -- I haven't found it in the factory service manual.
So, good luck -- try to contact the company reps when you narrow down your choices.
hj
Old Jan 13, 2013 | 02:37 AM
spiggy769's Avatar
spiggy769
(Removing Double Post)
Old Jan 13, 2013 | 02:40 AM
spiggy769's Avatar
spiggy769
hj
What model Equus do you have for I was looking at them and what you described is mode 6.
As for interpreting it....though it is for a Ford Expedition...I found This
where the guy explains it rather well. He does say that determining the percentage is particular for that make of vehicle....I haven't checked AllData yet but if it is not in there I am sure that if you ask the guy he can hook you up with it if known...
Old Jan 13, 2013 | 08:05 AM
tjc transport's Avatar
tjc transport
i ain't rite
i have no idea what mode 6 is, but i use 2 scanners. the autoXray 6000 EZ zcan, you can get it at amazon.com for $300:
Amazon Amazon
and the autoenginuity pc based scanner that you can pick up from RiffRaff diesel for around $325. both are very easy to use.
Old Jan 14, 2013 | 12:45 AM
ford2go's Avatar
ford2go
OK, I looked it up
INNOVA 3140 Diagnostic Code Scanner for OBDI and OBDII Vehicles : Amazon.com : Automotive INNOVA 3140 Diagnostic Code Scanner for OBDI and OBDII Vehicles : Amazon.com : Automotive
The vid was interesting, but the mode6 stuff is vehicle specific -- i.e.different manufacturers do things differently. I have a list of tests that I found that I think are relevant to my mopar, but they could be for a different model.
ezines like motor ( motor.com) and motorage(motorage.com) have published various articles about what you might be able to do.
Anyway, I've never understood why the scanner folks don't just say mode 6 -- it's in the OBD2 standard. The Equus manual is quite vague about the menu item that gets you to it.
Also, if you are thinking about this scanner --it's 'live recording' time is quite short --on the order of 10 seconds. So, if you hook it up and try to record parameters as you drive, that's all you'll see when you download it later. Not to say that it's not interesting, but it's not very long.
hj
Old Jan 14, 2013 | 03:46 AM
tjc transport
i ain't rite
i googled it too, and could not make any sense of what i was seeing.
Old Jan 15, 2013 | 09:52 PM
therifleman556's Avatar
therifleman556
Tom, I have the Autoxray 6000 as well. Have you ever had problems with "vehicle not responding" messages? It's only happened to me twice (both GMs, go figure). Other than that I like it very much. Updates available online and OBD-I compatable as well. I tried it on our 2011 and it gave me real time data right down to timing and vac/boost.
Old Jan 16, 2013 | 06:32 AM
tjc transport
i ain't rite
two or three times, and each time it was because of a blown fuse not sending power to the obd port.
Old Jan 25, 2013 | 12:18 AM
Mr.Ford 351W's Avatar
Mr.Ford 351W
i have blue point mircoscan, bought of the truck.
I seen on ebay for around 200 bucks..
Old Apr 22, 2013 | 11:46 PM
Hotairjunkie's Avatar
Hotairjunkie
TJC, do you know what the difference is between the AutoXray 6000 and the 7000? And please don't say "1000"...lol
Old Apr 23, 2013 | 04:43 AM
tjc transport
i ain't rite
not exactly sure. but i can say the 6000 will only do basic diesel stuff like read codes only. from what i read the 7000 is a lot more diesel friendly.
it will get farther into it like monitoring engine functions. nnot sure though, because i never used one.
Old Aug 11, 2013 | 04:23 PM
sandrat's Avatar
sandrat
Have something similar
Amazon.com: Equus (EPI31403) CarScan Pro Scan Tool with OBD1 and Graphing: Home Improvement Amazon.com: Equus (EPI31403) CarScan Pro Scan Tool with OBD1 and Graphing: Home Improvement
Happy with it for what it is: quick code ripper that can also do OBDI for when the shop's stuff is tied up & I need to read/clear quick. Kinda wish it cleared KAM, but again, it does what I need it to.
Old Aug 13, 2013 | 07:19 AM
JWA's Avatar
JWA
The video about Mode 6 by Spiggy769 is fascinating and very, very informative! In fact it may prompt me to further explore my modest Actron CP9580 a bit further.
Learn something new every day here.
