Code 334
Old Jan 21, 2013 | 06:48 PM
CraigK's Avatar
CraigK
I checked the voltage and it looks to be correct. .94 volts at idle, EGR closed.
While I was there I put a vacuum at 2.5 inHg and the voltage went to 3.2 volts which seems to be pretty right on.
Now I'm really stumped.
Old Jan 22, 2013 | 02:15 PM
rla2005's Avatar
rla2005
Code 334: EVP circuit above the closed limit of 0.67 volts.
Your test results indicate your closed voltage is 0.94 volts. There is the cause of your code.
That does not necessarily mean the EVP is bad. Many times the EGR valve pintle cannot fully close because of carbon build up on the seat. Inspect/clean the EGR before trying a replacement EVP.
Old Jan 22, 2013 | 03:43 PM
CraigK's Avatar
CraigK
Ahh, I didn't read it carefully. It's supposed to be between .24 and .67 with the EGR closed at idle for both the grey and black EVP. I looked at the chart and it says 0% should be .90 volts with a margin of error of +/-.2. I thought 0% would be a closed EGR at idle.
Old Jan 22, 2013 | 04:52 PM
rla2005's Avatar
rla2005
For a gray colored EVP the closed EGR voltage should be between 0.24 to 0.67 volts. It's easy to overlook.
Old Jan 22, 2013 | 06:14 PM
CraigK's Avatar
CraigK
The tech page doesn't say if those values are for a black or a grey. If that's for a grey, what is it for black?
I noticed when the EVP is installed the pintle is being pushed up a little by the EGR even when the truck is off. Maybe the EGR isn't closing all the way.
Old Jan 22, 2013 | 06:47 PM
rla2005's Avatar
rla2005
There is some preload on the EVP sensor, that is normal. That is another reason why it is hard to point the root cause at the EGR or the EVP. It is a process of elimination.
I have never had to deal with a black EVP, so I do not know what the closed values are nor do I care.
Old Jan 24, 2013 | 09:28 PM
CraigK's Avatar
CraigK
I figured for $30 I'd change the EVP and see what happens. Happy to report all codes are cleared. Thanks for the help.
Old Jan 25, 2013 | 07:07 AM
rla2005's Avatar
rla2005
Great news. Glad to see you got it fixed.
Old Jan 25, 2013 | 08:07 AM
timbersteel's Avatar
timbersteel
Good job!!!
Old Jan 9, 2019 | 09:32 AM
1992rustbucket's Avatar
1992rustbucket
I know im extremely late on this post but I was just wondering if this fix held up to what you said and never started doing that again?
2oo1 4x4
1997 - 2003 F150
May 15, 2014 08:05 PM
danboy282
Bronco II
Feb 10, 2012 12:16 AM
ESCAPESTER
Escape & Escape Hybrid
Oct 13, 2008 09:31 PM
ram10
Modular V10 (6.8l)
Mar 14, 2007 04:59 PM
BroncoScott
Apr 20, 2002 10:25 AM
