3.08??
Old Aug 18, 2002 | 04:48 PM
KyFord351's Avatar
KyFord351
3.08??
Is a 3.08 gear ratio really that bad? I could give a ***** less about highway speeds but how will it handle on a straight race?
Old Aug 18, 2002 | 06:41 PM
topo4u2's Avatar
topo4u2
3.08??
It is a good highway gear but if you want pulling power or lots of take off from the line you better go a bit higher to a minimum of 3.55
Old Aug 18, 2002 | 06:53 PM
DeGideo's Avatar
DeGideo
3.08??
For even more snap off the line & pulling power, you might want to go with 4.10:1 gears.I had a '93 F-250 4x4 with a 351,and the 4.10:1 gears,and it was a good puller.The only thing about steep cogs is your truck's fuel mileage will go down,but like I said, the 351&4.10s are a good combination,otherwise.
Old Aug 18, 2002 | 10:09 PM
MustangGT221's Avatar
MustangGT221
3.08??
The size of your tires plays a huge roll too. W/ stock tires i'd recommend 3.73s or 4.10s. 3.55s will be marginal with stock tires, nothing finominal. 4.10s will be a little tough on your engine if you drive on the highway a lot. What size tires are you running?
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 18, 2002 | 10:53 PM
firestorm's Avatar
firestorm
3.08??
