lets see your wheels!!
Old Jan 13, 2013 | 11:27 AM
  #31
Andrew010's Avatar
Andrew010
I believe this thread has been hijacked.......
Old Jan 13, 2013 | 11:33 AM
  #32
Tomahawk's Avatar
Tomahawk
Oh no, my tires are dusty.
Old Jan 13, 2013 | 11:43 AM
  #33
throttlejocky316's Avatar
throttlejocky316
Is there a lift on your truck? What brand and size of tire are you running? Rim size and do they rub? I like the look and have the same color scheme....
I have a 4.5" lift on the truck, and I have no rubbing issues. The tires are Hankook ATM 325/60R20. I really like the tires because they are quiet and have good snow traction. They have load range E with a max load of 3750 lbs which will be good for towing my 5er.
Old Jan 13, 2013 | 11:51 AM
  #34
SavageNFS's Avatar
SavageNFS
What a FANTASTIC picture!
Old Jan 13, 2013 | 12:06 PM
  #35
Andrew010's Avatar
Andrew010
No one likes dusty ole tires. Better get her to the car wash ASAP!
Old Jan 14, 2013 | 02:25 AM
  #36
2012F250SUPERDUTY4X4's Avatar
I hope I did not have anything to do with it?!
Old Jan 16, 2013 | 06:58 PM
  #37
dixoncity's Avatar
dixoncity
How much Lift?
Will 2 1/2 Lift do for most of these nice shinny wheels and 35 inch tires? Savage, nice truck. How much lift do you have, for both front and rear?
Thanks
Old Jan 16, 2013 | 07:31 PM
  #38
SavageNFS's Avatar
SavageNFS
Thanks
Thanks for the kind words...
I have the snow plow prep package (heavier springs) and a 2 1/2" leveling it up front. In the rear, 4" blocks. I have plenty of room to clear the 35's, but I've heard of guys withOUT the snow plow prep package rubbing slightly with just a 2 1/2" leveling kit. A lot depends on the tires chosen for rubbing to occur. Obviously a Nitto Trail Grappler or Toyo Open County MT will have a better chance of rubbing than an all terrain tire with less sidewall lugs.
Old Jan 16, 2013 | 07:37 PM
  #39
dixoncity's Avatar
dixoncity
Thanks, I have the plow prep as well, so this definitely helps. Did you have to add the 4 inch blocks, or were they stock? Thanks, again.
Old Jan 16, 2013 | 07:49 PM
  #40
SavageNFS's Avatar
SavageNFS
They are not 4"...I keep screwing that up. The blocks were added by the original owner (not me)...they are apparently difficult to find. I have actual cast-iron, FoMoCo 3.5" blocks withOUT bump stops. The bump stops have not been cut-off...
They were on the truck when I got it, but they are definitely not a F-250 block. I believe they are F-350 SRW camper prep package blocks, but I've never confirmed it. Sorry. I do know they are 3.5" tall. The picture is a crappy angle, but I' assure you they are 3.5" and not 4" blocks.
The height is very important to me as any higher and my fiver isn't level or my four wheeler trailer and I'm kind of OCD about level trucks and trailers. I don't like any rake at all.
Old Jan 16, 2013 | 08:01 PM
  #41
darren32's Avatar
darren32
Ya.... me too
A lot depends on what offset you go with.
Stock is +40mm
325/60R20 (35.6" x 13") work on a stock turck with stock offset wheels and only rub at full lock on the control arms.
The same tires on -12mm offset rims DO NOT work. They hit hard on the bumper bracket and the sheet metal at the back of the wheel wells. I tried it and I could not even turn enough to get out of my driveway (Until I cut the bumper brackets off with a grinder and bent the sheet metal at the back of the wheel wells). But not everyone one likes to cut / beat new trucks so that is why I say it does not work.
Thanks
Old Jan 17, 2013 | 08:37 PM
  #42
Jigger2020's Avatar
Jigger2020
Old Jan 18, 2013 | 12:09 PM
  #43
TosaFords's Avatar
TosaFords
OEM XL 17" steel wheels painted with PlastiDip. Cost me all of $20 to have black wheels.
285/75/17 GoodYear Duratrac tires
The tires have about 20k on them by now and still have tons of life left. I am in no way easy on the truck and have roasted the back set plenty of times.
Old Feb 1, 2013 | 08:16 AM
  #44
WildWildWest's Avatar
WildWildWest
Factory 20" Lariat wheels were replaced with 18" Core Racing "Rogue" wheels. Currently has BF Goodrich All Terrain KOs on it, will be putting Cooper Discoverer AT3's on it when they are done - probably spring.
Old Feb 1, 2013 | 08:29 AM
  #45
SavageNFS's Avatar
SavageNFS
I'll bet that truck and fiver look pretty epic together. Looks great!
