fixing cracked frame?
Old Jan 7, 2013 | 02:48 PM
rustywheel68's Avatar
rustywheel68
so...now that the bed is off, i can finally get a good look at it...
ouch.
a couple of questions:
is that big hole supposed to be there?
and the big question...how would you go about fixing/patching/strengthening this?
Old Jan 7, 2013 | 03:12 PM
Skip1970's Avatar
Skip1970
wow that frame is beat! anythings fixable tho.
Old Jan 7, 2013 | 04:17 PM
Osiyo59's Avatar
Osiyo59
I would only trust that repair to a repair shop that knows how to do full frame vehicles. My personal opinion would be to just find another frame. I had to do it on my first slick.
Old Jan 7, 2013 | 04:19 PM
C G B's Avatar
C G B
I think the hole is supposed to be there.
I would sandblast to start with. Then bevel the crack as much as possible. At that point actually straighten the frame. Id cut a pattern off the good side to see how much you need to move it. Once you have the frame where it needs to be, weld it solid from both sides. I would then clean up the outside to make it look decent, and clean up the inside. I would plate the inside area with another piece of steel, probably 3/16" thick, about a foot long, that fits the rail tight, top to bottom.
Old Jan 7, 2013 | 05:13 PM
carras's Avatar
carras
my 1966 shortbed does not have the large hole, only the 2 small ones.
Old Jan 7, 2013 | 06:02 PM
hiball3985's Avatar
hiball3985
What are the things welded to the top of the axle housing for? Was that a coil spring?
Old Jan 7, 2013 | 06:08 PM
rustywheel68
yep...
now that we've got Carras' photo for comparison- here's what i *think* the crazy PO may have done...
i think he may have drilled the hole in the frame and used it as a retainer for the top end of the coil spring.
Old Jan 7, 2013 | 06:11 PM
rustywheel68
thanks for that-
question: if you look back at my pic- notice how the bottom of the frame (to the left of the crack) has a lip that is sort of bent downward?
is yours like that, or perfectly straight c-channel? i don't have anything to compare it to.
Old Jan 7, 2013 | 06:12 PM
tinman52's Avatar
tinman52
Welder User
This.
Weld it up...if you can't weld it, take it to someone who can.
Old Jan 7, 2013 | 06:22 PM
hiball3985's Avatar
hiball3985
Originally Posted by rustywheel68
yep...
Good old Hillbilly overloads . They may have added the hole to keep the crack from spreading to the main section. I wouldn't weld the crack, I would put in a plate.
Old Jan 7, 2013 | 08:21 PM
carras's Avatar
carras
thanks for that-
Mine has the bend that you mention
Here's a closer look. The bend makes room for the rear shock (not shown)
Old Jan 7, 2013 | 08:32 PM
rogue40's Avatar
rogue40
Yep. I'm a welder and this pretty much nails it. I've used this method on anywhere from log and dump trucks to light pickups and trailers and it has never let me down.
Old Jan 8, 2013 | 04:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
yep...
1965/78 LTD's have coil spring rear suspension w/a track bar. It's possible PO got a 9" from one, then tried to install the 9 and the coil spring suspension.
Old Jan 8, 2013 | 02:27 PM
vdavie's Avatar
vdavie
Where do you live? I am buying a donor truck and will not be using the frame..you are welcome to it when i get the truck.
Vince
Old Jan 8, 2013 | 02:36 PM
85e150's Avatar
85e150
No, the pic shows the remains of a coil spring welded directly to the housing. OEM had a "cup" if you will to hold the spring.
