Spongey Brakes
Old Aug 27, 2020 | 06:08 PM
  #31
mikie50's Avatar
mikie50
Sure did
Turns out that Ford issued a notice on this problem for the F350 series in they years around my 1990. They put too small of a Master cylinder on the trucks. I had to have an expert look into this and find it. He put on one with a larger inside cylinder. I think mine was 7/8" and he went to 1 1/8". The largest he could without modifying the mounting holes. The Power boosters on these are so powerful, they override everything. I spent over a month figuring this out. Even had to drop the camper because it wouldn't fit in the shop I took it to and they couldn't lift the 10,000 truck. Now if somebody can tell me how to make the self adjusters work properly, I'd be a very happy camper. Good luck with yours.
Old Aug 27, 2020 | 06:44 PM
  #32
NatalieAtwater's Avatar
NatalieAtwater
Whaaaaat?! Crazy.
I wonder if this could apply to a 1968 Ford f100?
Old Aug 27, 2020 | 08:02 PM
  #33
mikie50's Avatar
mikie50
Ford is famous for under-powered braking systems.
Old Aug 28, 2020 | 09:46 AM
  #34
kr98664's Avatar
kr98664
Originally Posted by NatalieAtwater
still have a pedal going straight to the floor....
This should help:
https://www.ford-trucks.com/forums/1...-bleeding.html
Our trucks have a quirk in regards to bleeding the system. This link explains why and has some methods to work around the problem. From my personal experience, pressure bleeding is the way to go. If you've had the system disassembled upstream of the pressure differential valve, regular bleeding just won't cut it, no matter how many times you try. Make sure the rear brake shoes are properly adjusted, too.
This process markedly firmed up the pedal on my stock '84 F250.
Old Aug 28, 2020 | 12:50 PM
  #35
FuzzFace2's Avatar
FuzzFace2
Originally Posted by kr98664
This should help:
X2, it was the only thing that worked on my 81 F100 as my system was also fully drained and apart for years while I did a cab off frame rebuild.
Dave ----
Edward Michael
17
Feb 2, 2018 06:04 PM
fordnurse
Dec 12, 2011 07:37 PM
god.boots
Apr 4, 2006 09:11 AM
8720fordfan
Feb 21, 2005 01:22 PM
msfprobass
Mar 6, 2003 06:35 PM
