Code P0470
Old Jan 3, 2013 | 07:43 AM
tonefordays's Avatar
tonefordays
Code P0470
Good day fellas,
This morning when I started up my truck, I noticed a pending code on my SGII. P0470 Exhaust Pressure Sensor. Can someone please educate me a little bit on this. Where is it located, what would cause it to go bad, can I test it, can this cause other things to fail?
Thanks for any input.
Old Jan 3, 2013 | 09:59 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
https://www.ford-trucks.com/forums/3...ch-folder.html
Old Jan 3, 2013 | 04:53 PM
tonefordays
So I got home today and took a look under the hood to see what I might be able to find. I found oil dripping from the underside of the turbo onto the top of the engine.
Some of the symptoms I've noticed over the past couple of weeks.
-Erratic idle, especially when cold. It's not real bad, but just enough to notice. Almost like there are small surges.
-Lack of power, sometimes it just doesn't seem as responsive to the throttle as I'm used to, could just be me??
-Puff of black smoke on start up. Seems to be blowing out more smoke than I remember, but only when the engine is cold.
Damien05
6.4L Power Stroke Diesel
May 1, 2015 04:58 AM
4inchlovin
13
Oct 14, 2010 01:04 PM
wescon
Aug 21, 2010 05:00 PM
wolfrace
Aug 15, 2010 11:54 PM
fluidp
Mar 15, 2009 04:56 PM
