5 speed trucks! 94 f250 clutch pedal housing wearingout
Old 01-01-2013, 01:58 PM
rollinblackcloud's Avatar
rollinblackcloud
rollinblackcloud is offline
Got zf5 in a 94 f250 7.3 the pedal in the truck is getting sloppy. I looked up there and the pedal connects to a rod that runs thru the housing to the right, towards the gas pedal, then pushes on the rod to the master cyl i suppose. Anyway all the bushings are wore and the pedal is gettin sloppy and has lots of play. Not disengaging all the wY. Any advise? Im sure this whole set up from ford is way expensive. And tryin to find a junkyard 5 speed of my truck is not gonna be easy either. Might be my only option. Anyone?
Old 01-01-2013, 02:09 PM
Hutch17's Avatar
Hutch17
Hutch17 is offline
What pedal? Gas? Brake?clutch?
Edit:sorry just saw the title
Old 01-01-2013, 02:18 PM
rollinblackcloud
Clutch pedal. The brake and clutch are on the same housing
Old 01-01-2013, 02:48 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
VERY common problem. Just get a new bushing kit and rebuild it
page 22
National Part Depot
Old 01-01-2013, 02:58 PM
rollinblackcloud
That link didnt work for me, but awesome, glad to know there are kits to rebuild! ThankS
Old 01-01-2013, 04:24 PM
kawamatt2's Avatar
kawamatt2
kawamatt2 is offline
The bushing set is still available from Ford. Brake and Clutch Pedal Shaft Bushings: F3TZ-2C342-A.
Also the bushing that goes in the clutch pushrod is available. Clutch Lever Bushing: E69Z-7526-A
Also, you will likely find that if the pedal shaft bushings are bad (and have been that way for long) the holes in the metal bracket will be worn and oval'ed. So when you put your new bushing setup in, they will wear out very quick. If this is the case, you can order a whole new bracket and pedals still from Ford. 92-97 Clutch/Brake Pedal Bracket: F3TZ-2455-A
Search these part numbers online for ordering.
Old 01-01-2013, 04:52 PM
Diesel_Brad
Link works, you just gotta give it a second to load
Old 01-02-2013, 06:48 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
OP is a CA resident ~ Closest FTE Ford Dealer Parts Dept sponsor: Horizon Ford Truck Center in Seattle (Tukwila) WA
F3TZ-2C342-A ~ MSRP: $20.50 // horizonpartsguy.com price: $14.26.
E69Z-7526-A ~ MSRP: $9.42 // horizonpartsguy.com price: $6.78.
F3TZ-2455-A ~ MSRP: $200.17 // horizonpartsguy.com price: $144.12.
Old 01-02-2013, 09:05 AM
conork's Avatar
conork
conork is offline
I have an 89 F-150 with a four speed in it...I believe we have the same bracket for the pedals. Mine literally snapped in half one day, after acting sloppy for a little while. I replaced it with a junk yard bracket, and now after about a year the pedal gets sloppy about once a week now, its really weird. I'll look for the bushings as well.
Old 01-02-2013, 09:10 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
DPDISXR4Ti is offline
Right, and then go to page 22 as you suggested. Looks like the after-market part# he needs is F-2471-2 for $6.48, keeping in mind that '94 is a change-over year for that part.
Looks like Ford realized they had a weak link and upgraded the manual pedal cluster to use the bushing from the A/T pedal cluster starting in '94.
Old 01-03-2013, 06:33 PM
kawamatt2's Avatar
kawamatt2
If we are going to start suggesting best prices:
F3TZ-2C342-A - $13.53 from TascaParts.com
E69Z-7526-A - $6.22 from TascaParts.com
F3TZ-2455-A - $132.11 from TascaParts.com
No, you have a completely different bracket setup. In no way interchangable with the original poster's setup on his 94'. Also, the part numbers of the bushings posted above will not work for your application.
Old 01-03-2013, 07:02 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
He was suggesting the closest parts supply that was also an FTE Sponsor. Tasca is over here in RI, and does not sponsor FTE.
Old 01-03-2013, 07:18 PM
joey2fords's Avatar
joey2fords
joey2fords is offline
i have this problem in my 1989 f250 4 speed as well. i am so glad i found this site before i started changing master/slave/clutch ... ... unless i am mistaken there are 2 different pedal brackets used for manual transmission trucks of this generation ... 1 is aluminum and the other version is steel . please correct me if i am wrong there. my bracket is made of aluminum. i grabbed one from the wreckers just in case the holes have been ovalled. my question is : are the bushing kits the same for both aluminum AND steel brackets ?
thank you.
oops ... i think kawamatt has already answered my question. does anyone have the part number for the bushing kit in my 1989 application ?
reloaderbill
01-18-2014 12:42 PM
WALFORD'S 56
03-12-2010 06:30 PM
ghunt
11-06-2007 06:58 PM
Schuby
1997 - 2003 F150
03-07-2004 08:15 PM
Quick Reply: 5 speed trucks! 94 f250 clutch pedal housing wearingout
