1978 - 1996 Big Bronco
pollution pump?
Old May 26, 2003 | 07:35 PM
SCREENZ's Avatar
SCREENZ
pollution pump?
Anyone know which size belt to get when taking off the pollution pump? Thanks for any help
88 bronco 351w
Old May 27, 2003 | 01:01 AM
greystreak92's Avatar
greystreak92
pollution pump?
I don't know the exact belt size but you should be able to measure and get close enough to count. If I am recalling correctly, smog pump is below the alternator but above the crank pulley. So, measure fron the center of the crank pulley to the center of the smog pump pulley. Then from center of the smog pump pulley to the center of the alternator pulley. Add the two measurements together. Then measure from center of the crank pulley to center of the alternator pulley and subtract that measurement from the total of the two previous measurements.
crank + smog + alt = "X"
crank + alt = "Y"
X - Y = difference in belt length
Note: This is an approximate measurement only. This formula does not take pulley circumference into consideration.
There is a much more complicated method that is more accurate but would take forever to post. Email me if you would like to discuss it.
Old May 27, 2003 | 01:51 AM
bronco351's Avatar
bronco351
pollution pump?
Hey, forget all that math, it hurts my head!! All you need to do is go down to yuor local parts store and buy a few belts that are different sizes. Which ever ones don't fit, just package them back up and return them!! Just make sure all you belts are smaller than the original one!!! HOPE THIS HELPS!!!
Old May 27, 2003 | 07:31 AM
bigric's Avatar
bigric
pollution pump?
Or you could just run a piece of string or rope as though it were a belt, then measure it and get the same size belt.
Old May 27, 2003 | 09:40 AM
SCREENZ's Avatar
SCREENZ
pollution pump?
Thanks for the help bros I just got this truck as a toy my fisrt v8 and first 4x4 Thanks again I think I'm gonna try the string out
Old May 27, 2003 | 11:31 AM
greystreak92
pollution pump?
Ok, ok guys....so I was going about it the hard way!
Old May 27, 2003 | 11:03 PM
bigric's Avatar
bigric
pollution pump?
Ah, but both of us neglected the effect of the tensioner... That's going to throw my method by an inch or so.
gameover1974
Jan 6, 2016 05:27 PM
gameover1974
Dec 13, 2015 01:08 PM
armashby
Jul 24, 2015 10:54 AM
Cdavis9
Jun 3, 2015 11:36 AM
Babin
Mar 29, 2005 02:52 AM
