Sponsored by: Real Truck
Oil Pressure
Old Jan 2, 2013 | 03:52 PM
MonkeyFarmer's Avatar
MonkeyFarmer
Oil Pressure
I have a 2012 F250 SD 6.7 L Crew XLT
Can't seem to find the engine oil pressure. A look at the wiring diagrams says there is a sensor so the 'puter has it. The Gage panel in the display has tranny and engine temps. The next page is blank.
Is there a way to program the display to show engine oil pressure?
Mike
Old Jan 2, 2013 | 06:53 PM
Tom's Avatar
Tom
Hi MonkeyFarmer, welcome to FTE!
Unfortunately you're confusing the fuel pressure switch with an actual pressure sensor, which the truck lacks. There is nothing on the 6.7L engine that has the capability of monitoring oil pressure, the switch does nothing but tell the PCM that there is more than a nominal amount of oil pressure. All recent Ford engines that I'm aware of use a switch rather than an actual pressure sensor.
So you can't get it to display because the PCM doesn't know!
Old Jan 3, 2013 | 08:50 AM
MonkeyFarmer
My bad.
Thanks.
olfordsnstone
Jan 21, 2014 02:34 PM
Choctaw Bob
Mar 10, 2011 07:09 AM
98FordTruck
1997 - 2003 F150
Aug 17, 2010 08:58 PM
Toyman
Nov 30, 2009 08:57 AM
460f350
Dec 8, 2006 07:34 PM
