Dizzy issue
Old Jan 1, 2013 | 03:39 PM
jetrinka's Avatar
jetrinka
Dizzy issue
The gear on the distributor (390 motor) shouldn't be able to be held still while spinning the rotor on the other end should it? Or am I misinformed about some sort of black magic that happens in these things? I went to go put the distributor back in and it just didn't feel right so I took it out and found this issue.
Old Jan 1, 2013 | 03:48 PM
Roger Carter's Avatar
Roger Carter
You should not be able to "spin" the rotor while holding the drive gear. The gear is held in place by a roll pin, located in the "collar" of the gear. The rotor is indexed to the shaft by a "dog" cast into the rotor.
There should be some movement between the gear and rotor, due to the advance mechanism.
Roger Carter
Old Jan 1, 2013 | 03:55 PM
hiball3985's Avatar
hiball3985
If it didn't feel quite right it is probably because the oil pump drive isn't lining up. A slight turn of the engine will allow it to drop in.
Old Jan 1, 2013 | 03:56 PM
jetrinka's Avatar
jetrinka
Thats what I thought. Its not just a little movement, I can spin one side completely around while holding the other stationary. Makes a nice little grinding sound when it does so as well.
I think I know why too. The timing chain set I replaced was the OE set and EXTREMELY loose. With both gears seated fully back I could almost slip the chain off the crank sprocket without moving the cam sprocket at all. I am actually confused as to how the truck ran. I am sure that this looseness is what broke the distributor.
Old Jan 1, 2013 | 04:00 PM
hiball3985's Avatar
hiball3985
If you can hold one end and spin the other there's a good chance the pin that hold the gear sheared. I doubt the timing gears had anything to do with that.
Old Jan 1, 2013 | 05:51 PM
jetrinka's Avatar
jetrinka
I wish it was just the pin for the gear. I could just replace that... Went out and looked at it closer and it must have broken the shaft towards the top of the distributor.
Old Jan 1, 2013 | 05:55 PM
hiball3985's Avatar
hiball3985
That is strange, I've never heard of one breaking, what could possibly cause that? Be glad it's not the pin, if the pin sheared it is caused by a major problem.
Old Jan 1, 2013 | 06:01 PM
jetrinka's Avatar
jetrinka
Yeah I don't know what happened or how the truck even ran for that matter. I've just been in the process of freshening up the motor, resealing, etc and I didn't even think to really look at the dizzy when I pulled it out. Just yanked it and set it aside. The truck ran relatively well actually.
And where it broke is weird too. It looks like it broke directly beneath the main plate the rotor rotates above (not sure what the actual name for this part is...) Hope that makes sense.
Perhaps one of my buddies that was over stepped on it or something... lol.
Oh and what do you mean be glad its not the pin? Just curious.
Old Jan 1, 2013 | 06:09 PM
hiball3985's Avatar
hiball3985
I've only seen a sheared pin once. It was caused by the oil pump coming to a stop..LOL. Later inspection found a small piece of metal in the oil pump gears. When the pump stopped it twisted the pump drive rod but it didn't break, the force of the cam gear still trying to turn the dizzy sheared the pin.
Old Jan 1, 2013 | 06:20 PM
hiball3985's Avatar
hiball3985
I was just thinking, and someone will correct me if I'm wrong, but I'm assuming you have a dizzy similar to the earlier ones I'm use to working on. Take the rotor off and look down the center of the shaft and see if there is a felt looking thing, that for upper bushing oiling, remove that and see if there is a small snap ring that holds the cam assembly down onto the shaft.
Old Jan 1, 2013 | 10:08 PM
jetrinka's Avatar
jetrinka
It got cold out so I will do that this weekend. haha.
On a side note, what works well to prime the oil pumps on these things? Is that a hex I see down there?
Old Jan 1, 2013 | 10:56 PM
jetrinka's Avatar
jetrinka
NVM. Looks like a 5/16 or 3/8 socket down there on a drill should do the trick.
Old Jan 1, 2013 | 11:23 PM
hiball3985's Avatar
hiball3985
There is a tool you can buy to do that. I have used a 1/4 drive and socket but be extremely careful LOL. Why do you want to prime it, is it a new engine or just been sitting for a long time?
Old Jan 2, 2013 | 04:50 PM
Roger Carter
Remember, the oil pump turns counter clockwise. If you use a drill motor to turn the pump make sure it is in "reverse".
Roger Carter
Old Jan 2, 2013 | 08:14 PM
jetrinka's Avatar
jetrinka
Its just been sitting for a while and I forgot to lube up inside the heads before I put them on . Just wanted to get some oil flowin before the initial startup.
