got a turbo kit today. prototype???
I picked up a turbo kit off of a seller on craigjunk. Guy says it came out of an early 94 idi truck. Has a banks round air filter deal, and has just one exhaust manifold, and the exit line for the turbo oil dump goes into the valve cover "which it came with" A garrett turbo on the setup. The interesting thing is that the turbo dump goes to torward the front of the vehicle. I'll post up some pictures tomorrow. I want to install this lickety split, and it looks like a breeze, as it is just the one manifold and the valve cover, and it is all one piece. Replace the old intake with the new hat assy. and all done. I do need to figure out an exhaust for the thing because of the strange way it dumps, it mounts directly over cyl 3 "may be different, I'm a chevy guy, forgive me" on the valve cover.
Happy New Year
Happy New Year
If you post this in the IDI forum, Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums , there are lots of guys with the Banks setup that can help you...
Received 3,730 Likes
on
on
nah, not a chevy unit, I have one of those already. I am curious, just got back as a guest from a dinner at a good friend's house, time to start researching.
on
and like i said, not stock. it is an abortion designed off the rayjay turbo system of the early 80's.
that system is made to only use the driver side bank of the engine. it will not make much boost because it will only be driven by 4 cylinders, and you will also get a bad cylinder backpressure imbalance using it.
i bet that is the reason it was pulled off and sold, the person that made it realized it was a bad idea after using it.
i would keep the turbo, and scrap the rest of it.
how only one bank???
the way its supposed to be setup is like on a chev 6.5. The pass side exhaust flows over to drivers side "opposite in a 6.5" and then through the turbo housing, besides being inefficient due to lower backpressure on one side than the other because of the distance that the gasses have to travel and loss of kinetic energy over that distance, I should still be able to install it and get like 10 psi right? I just need a little more umph to drive 18,750 lbs 2200 miles home. after that, I'll devise a much better system. can I not install this? would it be bad for the engine? I already bought it, not much left at this point but to use what I have.
thanks
Nintendo
thanks
Nintendo
on
