how do i adjust timing?
Old May 26, 2003 | 03:44 PM
bugeyed's Avatar
bugeyed
i have a 95 f-150 and i think the timing is a little off. How do i adjust this. Does this have to do with the lifters clicking against the valves, also how can i fix that do i need new lifters? thanks.
Old May 26, 2003 | 05:03 PM
steve83's Avatar
steve83
Get a timing light & a distributor wrench, and read the instructions on the emissions sticker in your engine compartment.
Old May 26, 2003 | 06:04 PM
bugeyed's Avatar
bugeyed
any ideas on the lifters clicking?
Old May 26, 2003 | 07:21 PM
steve83's Avatar
steve83
I'd do a tune-up first - the valve tap could be caused by preignition or some other basic problem. Start with the easy stuff and see if it goes away. For the second step, you might buy a cheap oil pressure gauge and install it temporarily to see how much you have.
Old May 26, 2003 | 09:50 PM
bugeyed's Avatar
bugeyed
hmmm i've done a full tuneup i'm not getting pre ignition its defintaly the lifters. i think they are worn and not opening the valves up all the way. I was out looking at the motor today and i think this is it, is there anything that can be fixed for this? or am i gonna have to have new lifters put in.
