I'm kinda resurrecting an old post. Never really got an answer the first time because I was troubleshooting a nasty stalling problem. I am wondering if my 96 F250 with the 7.5efi should go to high idle of about 1100 rpm at first startup for a minute before settling down at about 700 rpm? I also have a 94 Bronco with 5.0 that at first start will high idle for a minute at about 1100 rpm before it settles at about 700.
All gas cars and trucks do it.
Even all the carburetor gas engines did it from way back until the choke open as they were on what was called a high idle cam.
They also run extra rich while this is going on.
I know my truck with a 351w idles up to about 1200 at start up and drops back down when its warm. My work truck has an EFI 460 and idles up to about 1400 until its warm.
Paul, is it safe to assume that would be a MAF Mustang computer on your 90 F150 HO with mass air flow conversion?
Yes that's right, and I'll add that at cold start the motor does have a slightly higher idle speed but it's only something like 800rpm and only for about 20-30 seconds. I can make it do exactly what the truck computer does with my tuner but why.
Yup, my 351 does it too. One of these days I'll add an HOA switch for this. I tried it on my truck with some jumper wires and gator clips... electrically driving the idle valve 100% gives me ~1400 RPM which is perfect for when I need to crank up the output from the air compressor. And then I can turn it off and not have it rev so high on a cold start either.
Just have to find a good way to route the wires and a good tie-in point.
