Sponsored by: Real Truck
4x4 Inop
Old Jan 2, 2013 | 05:08 AM
  #31
hookedondiesel's Avatar
hookedondiesel
Originally Posted by jsavin
45 for the code read or 94 for a brand new module......
Ya, I hear ya, but what if it's "not' the module.
Old Jan 2, 2013 | 07:02 AM
  #32
SC_Hoaty's Avatar
SC_Hoaty
Originally Posted by hookedondiesel
Ya, I realize that, but I wouldn't want anyone to ground out that pin for testing purpose's, until I could see (inside the module ).
That may not be the point of ground, as it's not indicated as a ground point,
just sayin. Wouldn't want to unknowingly damage an chip inside.
Thats just me...lol
My next step, when weather permits, will be to check all grounds and power
to the module's, open up the module and check for corrosion etc.
I'll also see what makes it 'tick" what type of "chips" are inside and can they be replaced individually.
After that, I'll have the codes read. CTC over here will read them for 45$.
JS, here's a few on ebay to give you an idea.
GEM module 1999 Ford Expedition Lincoln Navigator 4X4 XL1414B205 XL1Z14B205AA | eBay
I got what you are saying. Your concern is not the grounding of the relay, but problems that could happen if the module piin 10 or 11 were connected to ground. I agree you should not be connected to the module while doing this type of troubleshooting.
Removing the relay from its socket and using some clip leads or other jumpers to connect the coil power and contact leads, and then grounding the coil ground to chassis ground would keep the module out of the loop.
After this is done, and the wires from the relay socket to the module verified to be good, (no shorts or grounds), then the problem is isolated to the module not doing its job.
Old Jan 2, 2013 | 07:06 AM
  #33
SC_Hoaty's Avatar
SC_Hoaty
Then sell it on eBay?
Or offer it to the next FTE brother with a 4x4 issue?
Karma
Mar 4, 2007 10:54 AM
busta-knuckles
Electrical Systems/Wiring
Oct 21, 2004 12:05 AM
yoohooman480
Jan 16, 2004 07:44 AM
AbadDriver
Bronco II
Apr 2, 2003 04:37 PM
