Hi I had a few quick basic questions about my idi. I have a 94 idi turbo auto transmission.
1) What is the oil capacity of the truck. including the oil filter.
2) what is the capicity of the transmission. I plan on changing the filter. It was also drained from the two hoeses that run the tranny fluid from transmission to the rediator.( I replaced the rusted ones). I do not know of those lines dranined the torque converter.
1) 10 qts with stock filter, 11 with 7.3 PSD filter
2) IF you completly drained it (including torque convertor) 16-18 quarts, more likley the torque convertor is still full so probbly only 10-14 quarts
so you think by draning the fuid out of the lines that run to and from the radiator I did not drain the torque converter? that is what i was thinking originally. You said to put in 10-14 quarts. how many do you put in yours? I was looking for an exact number just to be safe.
Honestly I dont know for sure but was probbly around 8-20 qts but I just poured from a 2.5 gallon jug untill the dipstick read just over full (also installed new cooler) and then ran the truck some and double checked
