I have a 99 F250 SD powerstroke 4x4 longbed, with 285/75R16.
What pressures do people run these at? running them at 65 all round at the moment, and the fronts look a little "flatter" than I would have thought ideal..
I run the same size in load range D, also at 65 all around. My truck is pig. Ranch hand bumper and a heavy 9 ft flat bed. 2000 7.3 4x4 SC LB
My other is a V10 4x4 CC SB also on 285's it's at 50 front and 45 rear. I may go lower in the rear as 45 just got the out side edges to touch the ground.
