Do you like to be challenged?
On a 52 the hood stay looks like this originally, right and left.
The hinge is toward the rear a bit on the cowl.
Because I have added a power brake booster I am not quite sure that even if I had an original 48-52 hinge that it would clear the booster and work so I did some scrounging at the wrecking yard and noticed my favorite donor vehicles ( 81-86 F- whatevers ) used a similar concept.
I grabbed a half dozen of these and went home to give things a try.
After cutting/welding, drilling and fabricating ( trying every possibility I could think of ) I have finally come up with a single hinge that does nearly everything I would like it to do.
Clears the booster with room to spare, keeps the hood up ( finally ) but when the hood closes will not keep it quite all the way closed. Rear of hood is still up above the cowl just a bit.
Actually both sides do this but the passenger side ( original stay ) can be pushed down and will stay down which I have learned is typical with these particular trucks when things get a bit worn out.
The drivers side however can be pushed down but it will pop right back up. Not much mind you, just a little bit above the cowl. Nothing drastic. Just enough to aggravate a person that cares.
I have stared at it for hours, is it because the hinge is winding down too tight or tighter than it normally would and is just relieving itself a bit or is it because the spring is not quite wound down enough.
I mean if I were to figure out a way to wind the spring just a little bit tighter than wouldnt I have even more staying up and open power for the hood ( which I really do not need since it seems to now work just fine the way it is ) but dosent staying up power or winding the spring tighter also mean less room for it too collapse and therefore not be able to close up within itself far enough to keep that hood even with the cowl.
The springs inherent design is too remain open or un-flexed which means hood open all the time so what keep the rear of these hoods down within the cowl area on these later model trucks?
I think it has to have something to do with there being a separate hinge and a separate stay on these later model trucks as well but not being an engineer I cant quite put my finger on how these work so that I can incorporate some of these ideas into my little project.
Does anyone have any ideas ?
Challenges? Love 'em. That's part of the reason I'm building the truck I am (link in signature). Being able to see ahead of what you are doing is also a big help, AND being able to dissemble and reassemble in your head helps a bunch too. I've spent hours upon hours planning and plotting in my mind to see how things are going to work, and if they'll work. It seems the harder, the better, and it gives you a real sense of accomplishment when things work out.
The newer style clock spring hinge can only come under more tension as the hinge closes.
An '80's style hood is meant to pop up against the safety latch when released from inside the cab.
Yes the hood is designed to pop up but that is at the front of the vehicle where it is greatest. In the meantime what is holding the rear of that hood down?
It has to have something to do with those flimsy hinges that are used on these later trucks, they must in some way lend a hand to all of this by pushing in one direction possibly while the stays are pulling in another.
I am having to consider the possibility that increasing the length of the new hinge upsets the throw or pitch of the un-changed spring within that same hinge.
Interesting stuff!
I have had to increase the overall length of stay to use the original mounting locations of the original hood stay, I had to use this location because it is where Ford reinforced the firewall with specifically located reinforcement ribs.
Move outside these ribs and the firewall will eventually give way because of the constant movement made against it from using the hinges/stays.
I also had to increase the length of stay to compensate for a certain degree of give within the spring, because of the weight of the hood in which it was not designed to support there is a certain amount it gives before it has gained enough friction within the coil to do its job.
It sounds like over thinking I know but cause and affect. I will go another round tomm with it. Maybe I will have the problem solved.
Might be better to bush the pivots. Rather than weld them up and try to drill them exactly on their old centers.
New style hood with this newer style stay/spring assy are flush with cowl, what keeps it there. You have the same upward force constantly on that wrapped spring pushing it upward, always wanting to be released....so what keeps it down?
The forward cantilever of the hood in an almost closed position is enough to overcome the increased spring tension.
How much does your hood weigh?
How long is it?
How long is it?
I am sure that the 52 hood weights considerably more than a mid eighties hood and unfortunately is is very long and therein lies the problems that need to be overcome.
I knew this when I decided to go this route but again it has re-freshed a few un-used brain cells and even if I do not succeed with this path it will not be a waste of time.
