Injector sealing problems
Old Dec 30, 2012 | 12:09 AM
BLADE35's Avatar
BLADE35
some more good info
Page 69: Unique Service Procedures
Page 70: Unique Service Procedures
Page 71: Unique Service Procedures
Old Dec 30, 2012 | 12:10 AM
jedlane8870's Avatar
jedlane8870
The bubble test is interesting if you have replaced the stock banjo bolts with the 6.4 bolts that dont have the check valves. There is no doubt that compression is entering the fuel system.
Old Dec 30, 2012 | 12:33 AM
BLADE35's Avatar
BLADE35
I forgot about the OEM CheckValve
There should be NO Compression in the Fuel Rail at any Point With or Without Check Valve
With a Check valve you wouldnt think the Air bubbles would make it to the Upper Fuel filter housing But I think the Bad ones do get air Reverse threw the check Valve
In therory the check valve should hold it in that head GReat Point
Old Dec 30, 2012 | 12:48 AM
BLADE35's Avatar
BLADE35
I even went as far as to run the Holddown bolt into each Hole with inject out and Make shure it Torqed out the Holddown and Not the Bolt Threads
I Measured the thickness of the Holddown and then Torqed the Bolt Alone to 26ft/lbs then measured the Space from Bolt Head to Head and as long as I had Less Space then the Width of the holddown I was Good
If that makes sense this only assures it Torqed properly
If the Holddown is Streched your still Toast
Old Dec 30, 2012 | 12:45 PM
jedlane8870
Is there an spec for hold downs other than comparing to a new one ? There was no problem with these hold downs with the old heads.
Old Dec 30, 2012 | 12:56 PM
jedlane8870
When the truck quit this time with the 6.4 banjo bolts it did not liquid lock the engine and i didnt see as much white smoke as it had the other times. When i pulled the upper fuel filter lid and spun over the engine fuel went everywhere, so compression was entering the fuel system.
Old Dec 30, 2012 | 01:12 PM
mustang_309's Avatar
mustang_309
did you have the fuel pump relay pulled when you did that?
Old Dec 30, 2012 | 01:54 PM
BLADE35's Avatar
BLADE35
You have to pull the Fuse for the FUEL Pump and FICM Before you crank the Bubble test
Old Dec 30, 2012 | 02:50 PM
jedlane8870
Never turned key on, used a remote starter switch didnt think the fuel pump would run with the key off. It was compression getting by the number 5 injector since the bottom o-ring was gone, most of the fuel left the filter housing at once.
Old Dec 30, 2012 | 03:02 PM
BLADE35's Avatar
BLADE35
I was thinking after you put New Parts then Test
While Valve covers off
Old Dec 30, 2012 | 03:05 PM
BLADE35's Avatar
BLADE35
How many Inject are New Ones
Old Dec 30, 2012 | 03:35 PM
BLADE35's Avatar
BLADE35
I suspect you might have suffered from loow Fuel press and or BAD Injectors and the injectors Leak fuel into cylinder and Burn the Copper Washer
But they are not installed at Spec
Low Fuel Press will Scar the Pluger in the inject and it will Hang up
Old Dec 30, 2012 | 03:58 PM
  #28
cheezit's Avatar
cheezit
injectors are not all the same nither are hold downs. they have 3c3z,4c3z,5c3z part numbers for a reason.
replace the injectors,o-ring kits and hold downs on the effected cyclinder and use a torque wrench to install, also lube the o-rings
Old Dec 30, 2012 | 04:07 PM
  #29
BLADE35's Avatar
BLADE35
Oh I thought it was just the injector Guts that was Diff
My Bad
Old Dec 30, 2012 | 04:42 PM
  #30
cheezit's Avatar
cheezit
emmmm that would make them different....no?
rule of thumb on injectors you can use a late style in an early truckbut doing the reverse is not recomended.
hold downs are very different
