q REALLY confused
Old Feb 27, 2013 | 06:44 AM
  #31
qmanconfused's Avatar
qmanconfused
ok ... things are still under deep freeze and 2' of snow here in upstate ny. but i've taken a day here and there to get some things started. i took my 302 and c-4 apart and got the motor over to the machine shop to do all the internals. the motor builder promised me double the h.p. (175x2= 350) on pump gas. yesterday i scraped all th 45 yrs of grime off the c-4. duzzent look too bad. it goes to the tranny shop this wk. and i've purchased a 72 jag. my partner in crime, daryll, took the fr and rear sus off the car and disassembled the various parts. today, the parts of that that can be sand blasted go to that guy today. the jag is sitting w/ no wheels or sus. in my drive way....thats real pretty! get rid of that this week also. so, things are starting to move. more with pix soon
Old Feb 27, 2013 | 06:50 AM
  #32
The Horvaths's Avatar
The Horvaths
You might consider using the Jaguar's fuel fill option(s). The locking caps look pretty tricked-out. I forget which fellow FTE'er did it, but, the credit's not mine.
Old Feb 27, 2013 | 07:09 AM
  #33
qmanconfused
i'll check that out when i get outside this morning. do you mean the whole filler neck or just the door and inner cup?
Old Feb 27, 2013 | 07:46 AM
  #34
ratthell52's Avatar
ratthell52
That GTO is identical to my first "fast" car that I purchased in the spring of '72 when I landed my first and only good job...Had same color but had an Olds 442 engine when I got it.
I only had the GTO for a few years, but had that job for over 30 yrs!
Old Feb 27, 2013 | 08:16 AM
  #35
qmanconfused
hey randy
then your GTO is the only other one i've known of that was the same color. it was a factory color called "slate blue metallic". when i was at the GTO nationals in columbus, ohio, in 2000 mine was the only one that color. imagine....600 gto"s and mine the only one. i changed the interior color from blue to parchment(off white) just before installation just because i really wanted the paint to POP....it duz. it kinda changes to grey at dusk, really pretty. i still have it. only 3,000 miles since then. now, if i only cud get this 54 effie done i'd be a happier camper!
q in 'cuse
Old Feb 27, 2013 | 08:24 AM
  #36
ratthell52's Avatar
ratthell52
Qman
I tracked down my old car 5 or 6 yrs ago; Parked under a huge White Pine tree for 10 years without a cover...Was not pretty!
Old Feb 27, 2013 | 08:20 PM
  #37
qmanconfused
one good thing, the pine sap made the car water proof! wadda u mean"thats not funny!" its only funny if its not your car.....you must have been sick to see it in that condition. i guess these car stories can't be all happy endings. too bad;(..sorry randy.
qman
Old Feb 27, 2013 | 08:44 PM
  #38
The Horvaths
I think he used the filler neck and maybe cut to fit. The hinged locking chrome caps are kinda cool. Yeah, not Ford stock. But I liked the look. Hints as to his front end.
Old Feb 28, 2013 | 06:45 AM
  #39
The Horvaths
Here it is: https://www.ford-trucks.com/forums/showthread.php?t=1217752
User "jrockdiddy" Look at the picture in the 7th post.
Old Mar 1, 2013 | 06:25 AM
  #40
qmanconfused
hey horvaths...
i went out and took a good look at that fuel door thingy on the jag. that could really work nicely. i'll get it off the jag before the junker comes back to get it
thanks for the heads up!
q in 'cuse
Old Apr 20, 2013 | 01:05 PM
  #41
qmanconfused
moving along
...at a knee jerk pace. my friend/mechanical partner, daryll and i are doing what we can and when we can to get this thing moving. my sand blaster took 2 months to do less than 2 wks work and really killed my momentum. so, I can't use him any longer as an excuse so here she goes.
I got a 72 jag and harvested the irs and ifs. again, it went to a blaster and I got it back in 2 wks. then off to the paint shop for color and clear coat....its medium gray. then we made a material list and sent off to rock auto for 95% of the sus. and steering and brake parts. some how, I don't know how but my 4 rear coil springs went missing!!! nobody knows nuttin'...bottom line is I had to order 4 new ones on the net. nothing another $150 won't cure...ordered and on the way. the rest of the irs and ifs parts are dribbling in and I think everything is here now except the springs. I've had jags in the past and I know it will be worth the effort and $$$.
I've painted the frame semi gloss black and taken off the factory front and rear parts that i'm replacing. daryll wanted to put the ifs and irs all together before fitting it to the frame. I discussed w/ him that AX advised me to fit it first but he wanted to do it the other way so.... AX wasn't available and we've started to do it the other way. i'm sure it will all work out in the end.
a little later tonite i'll get some pix on and show you guys what happening. i'm starting to get excited about it again but it takes a while at 67.....between my naps that is...zzzzzzz
Quentin in Syracuse
don't hold back on the comments...its all good!!!
Old Apr 20, 2013 | 01:29 PM
  #42
arctic y block's Avatar
arctic y block
Wind on her Q-Man. After what you have been through I am suprized ya want to do anything. At 60 years I can't even keep up with the house work after my two boys. Had to hire help just to put plugs in the bronc the other day. What a difference that made.
Old Apr 20, 2013 | 02:30 PM
  #43
Mervy49's Avatar
Mervy49
TOTALLY awesome, Your handicraft shines. I aspire to achieve your level of accomplishment.
Here it is...Saturday morning and I'm trying to make a set of headers fit? Small bock headers...guaranteed to fit....phhhttt!....
I love the GTO.
Old Apr 21, 2013 | 01:53 PM
  #44
AXracer's Avatar
AXracer
The fresh paint will be easier to remove with thinner than sanding off old paint when you start welding in the boxing plates and mounting crush tubes. If you used expensive catylized frame paint then you'll have to grind it off, but then you'll better see how many $ worth of dust you sweep off the floor. At least you'll know how much paint you'll need for the repaint and how much he'll charge again for his labor.
Old Apr 21, 2013 | 05:22 PM
  #45
qmanconfused
some pix of the 54
I think they loaded....
the 1st pix is one of the 302 that the p.o. told me was a good motor. I took it to my machinist to "clean up" and he told me it was junk. the crank had wobbled from a bad hook up to a trashed transmission. the p.o. also gave that c-4 to me as a good one. WRONG...good thing I have a 4.6 lincoln motor & trans. that I know is good. even tho it needs a head gasket.
2nd pix is 3 spots on the front frame on each side where I think the p.o. had welded 1/4" plate pieces to mount a snow plow!!! go figure.
third is, oh hell, I don't remember but you see the frame and the jag rear end with the brakes on.
i'll get more organized as I go but the computer thing is harder than the build
more soon
q-man
Truxx1956
May 21, 2009 12:02 PM
C-700
Apr 6, 2006 05:32 PM
51dueller
28
Apr 2, 2003 09:14 PM
