Sponsored by: Real Truck
'03 5.4 ignition problems
Old Dec 28, 2012 | 07:37 PM
Thunderduckie's Avatar
Thunderduckie
Hey gang. I have an '03 with the 5.4 in it. Yesterday I noticed the truck would "chug" when I would accelerate and now today it is idling very choppy. Pretty certain it needs new plugs (110k on the original plugs) but with it being so cold out I was hoping to put that off until Spring.
My question is, and I know this sounds silly but I really don't know, is there a way to check the truck to find out which plug or plugs are fouled? Also, in case it isn't a plug, how do I test the coils to know if they are bad?
This is my daily driver so I need to get her up and running again ASAP.
Old Dec 28, 2012 | 10:02 PM
peehound's Avatar
peehound
4wd High
When the plugs go south (100k is about then), the coils will follow; yes the OBD codes will tell which it is, but you're probably due for plugs & a coil or 2. BT, DT.
Old Dec 28, 2012 | 10:07 PM
Thunderduckie
Thanks peehound. Not really encouraging (sounds like I gotta do the 6 hour spark plug swap) but I appreciate you taking the time to respond.
Skatermike24
May 9, 2017 12:12 AM
reptar0077
Feb 17, 2016 11:22 PM
cdherman
2004 - 2008 F150
Apr 5, 2011 07:16 AM
palindromelol
Jan 22, 2008 11:46 AM
Buck Waddell
Modular V8 (4.6L, 5.4L)
Mar 23, 2007 09:49 AM
