Powerstroke or not
Old May 26, 2003 | 06:49 AM
wls's Avatar
wls
Powerstroke or not
I have a 92 F-250 with what I believe is a powerstroke, my question is I see some 1993 listed here in the pre-powerstroke section, is mine a powerstroke or not, the fenders say powerstoke LOL. Another question I have, my 2002 F-250 has 525 lb of torque, what is the torque of a 1992 7.3. Thanks
Old May 26, 2003 | 11:31 AM
Freight Train's Avatar
Freight Train
Powerstroke or not
Welcome to FTE
I think somebody slapped those badges on the fender, thats all. Look at the 2002 you have, the two engines should be entirely different. The PSD (Power Stroke Diesel) should say Direct Injection on top.
The motor in that 92 is an IDI, In-Direct Injection, it uses a mechanical injection pump to supply the fuel to a pre-combustion chamber. The PSD uses the HEUI System, Hydraulic Electronic Unit Injector, to fire the fuel directly into the cylinder. The PSD is computer controlled, the IDI isn't.
Ford used the 6.9L IDI from 83(I think) until 87, then used the 7.3L IDI from 88 til 94.5, then began using the PSD from 94.5 till 2002. For 2003 They have a new 6.0 PSD which is even stronger than the 7.3 PSD. From 93.5 till 94.5, the IDI came with a factory turbo.
Not too sure on the torque output for the 92, so I'll leave that to someone else, but I think it's around the 400 ft/lb range.
