cracked exhaust manifold
need some help from the experts, We just installed a reuild long bolck in a 06 f150. its the 5.4L. used new exhaust manifold hardware and gaskets, torqued the studs and nuts per the specs. runs good, no codes but we have a slight surge, about 25-30 rpm, most noticeable at about 1700 rpm. with the code scancer in it we see a variation in the rpm, the short term fuel trim and the o2 sensor values. we noticed a crack in the right side exhaust manifold, near the rear, on the top. would this cause the surge problem. how can this be fixed. i have a mig welded but dont think it will work on cast. can it be brazed or is there some other way to fix.
We are open to any ideas.
thansk
gary
thansk
gary
thundersnow70
16
11-13-2010 09:35 PM
quentinorciuch
07-19-2007 12:50 AM
351ballsofford
05-25-2004 07:30 AM
shawn h
11-24-2003 06:00 PM
