The lights burning...
Old Dec 28, 2012 | 01:30 AM
joshofalltrades's Avatar
joshofalltrades
you can find the relays at any parts store or junkyard, and can find the sockets that fit them at any parts store. personally, i pocket the relays at the junkyard, and buy their sockets from the parts store.
Old Dec 28, 2012 | 01:33 AM
JJray's Avatar
JJray
Lol ill remember that thanks!
Old Dec 30, 2012 | 03:28 PM
JJray's Avatar
JJray
I got the new switch and pigtail on today. Everything worked fine, at first.. Now it keeps blowin fuses and the wires getting hot. So pretty much exactly the same stuff. I found a chunk of ice that had a power wire in it an might have shorted the system but its still blowin and burnin.
Old Dec 30, 2012 | 04:07 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Which fuse is blowing?
Which wire is getting hot?
It might help everyone if you could be a little more concise.
Old Dec 30, 2012 | 04:11 PM
JJray's Avatar
JJray
The fuse to tail/parking lamp
And the wire from that fuse to the headlight switch.
Old Dec 30, 2012 | 04:16 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
But not the wire from the headlamp switch to the tail/parking lights?
Old Dec 30, 2012 | 04:21 PM
JJray's Avatar
JJray
Non of the other wires felt hot. If it helps it doesn't blow the fuse right away. It takes a couple min for it to blow.
Old Dec 30, 2012 | 04:40 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I wish I had better ideas, but I don't have a diagram or an EVTM for an '83 F-250.
Seems to me that it would be best to put a relay on the output and run a heavier wire to the rear.
What amperage is the fuse supposed to be?
Old Dec 30, 2012 | 04:42 PM
JJray's Avatar
JJray
Its supposed to be a 15 amp but im using a 20amp
Old Dec 30, 2012 | 04:46 PM
CountryBumkin's Avatar
CountryBumkin
I have a wiring diagram for a 1982 F250. It is already scanned and can be e-mailed if you want a copy.
Old Dec 30, 2012 | 04:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
No wonder the wire is melting.
The fuse is supposed to protect the wiring and switchgear.
I don't care how many stop/turn/marker lights you have back there, you have a short to ground somewhere in that harness.
If I were you I would be looking for it before it causes the new switch & plug to melt down just like the last one.
(and please, use the proper fuse)
Old Dec 30, 2012 | 04:49 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Not sure if '82 is the same.
Can you post it to the forum?
Old Dec 30, 2012 | 09:13 PM
  #28
Franklin2's Avatar
Franklin2
The brown wire leaves the switch and then spreads all over the whole truck, front to rear with splices everywhere, powering all the running lights. If you could somehow have a bag of fuses, and could separate the truck into pieces, you could narrow down where the problem is.
I also had a thought. If you could get several people to stand around the truck when it's not very light outside, put a fuse in, and then pull the lights on and get everyone to check their end of the truck. If some of the lights are dimmer than others, or completely out, then you can pretty much figure that's the area the problem is in. For instance, if the rear taillights did not come on, or were very dim, then you can probably assume the problem is at the rear of the truck. There is a factory plug back there you could unplug to verify if the fuse quit blowing.
Old Dec 30, 2012 | 09:22 PM
  #29
JJray's Avatar
JJray
Ill try that out. My next step was gonna be just replicate the harness with new wires and swap them out (only cause its old and crappy) but ill try the free way out first.
Old Dec 30, 2012 | 10:04 PM
  #30
ctubutis's Avatar
ctubutis
A user-added trailer harness is often the cause of these kinds of things.
That brown wire also feeds the rear license plate illumination.
I would visually inspect the harnesses and all the sockets.
Jim is correct, the fuses are to protect the wiring. Using an over-amperage fuse WILL melt your wiring... you're shooting yourself in the foot doing that....
