Traile backup lights
Old Dec 26, 2012 | 09:49 PM
rodneywar's Avatar
rodneywar
my bad i got confused with the pics i blew em up the ones with the caps on em are for the trailer i got to look at mine been a while since i looked at em
Old Dec 26, 2012 | 09:57 PM
ReBilld's Avatar
ReBilld
I'm pretty sure the one you're holding in the pic is the unused trans plug.
Old Dec 27, 2012 | 01:16 AM
Splatts's Avatar
Splatts
U fellas know right off hand what it takes to get the relay setup off the side of the fuse box. Just so I don't go in there with a bucket of tools and still not have the right one.
Old Dec 27, 2012 | 11:15 AM
rodneywar's Avatar
rodneywar
Yep I checked my truck bill is right it is for the auto cause I have one and it is plugged in to the auto harness
Old Dec 27, 2012 | 03:38 PM
Splatts's Avatar
Splatts
Would the E series van have the same relay setup?
Old Dec 27, 2012 | 08:34 PM
rodneywar's Avatar
rodneywar
That I am not sure of
Old Dec 27, 2012 | 09:15 PM
ReBilld's Avatar
ReBilld
Me either, I've never messed with the vans. But if you have access to one, it would be worth checking.
Old Dec 27, 2012 | 09:41 PM
Splatts's Avatar
Splatts
I ended up gettin one off of an f250 gasser. Some of the ones I saw had a place for 4 relays. The one I grabbed has 2 relays with matching part numbers that bill mentioned. But the box w/pigtail was one number off. Instead of f6tb it was f4tb or f7tb. I will verify in the morning. I plugged it in and I get the aux power but haven't Ben bl to check the reverse.
I noticed one of the plugs on the pigtail only had 3 wires and the plug on the truck has 4. I sure hope i dont need that other Wire to get the trailer Reverse lights to work. I would imagine i could add a wire if needed but ive never done it. It's the power supply side of the relays. I will get some pics and the part number tomorrow of the one I got.
Oh yeah and them things are a PITA if u don't have a 5mm socket to remove the 2 bolts. I think I jinxed myself by what I stated earlier. Lol
Old Dec 27, 2012 | 09:48 PM
ReBilld's Avatar
ReBilld
I checked all my other parts trucks last night when I went out and looked for the part #s, and that truck was the only one that had it.
Old Dec 27, 2012 | 10:45 PM
Splatts's Avatar
Splatts
I'm goin to takes closer look at pigtail part number and see if I can find some sort of wire identification online somewhere. Which wire powers what type of thing
Old Dec 28, 2012 | 08:43 AM
Splatts's Avatar
Splatts
The aux or battery charge should be hot all the time when the truck is started. Correct. I got to figure out why it only came hot when the lights to the truck got turned on. Hmmm sounds like some wiring mixup is goin on. DANG IT!!!
Old Dec 28, 2012 | 09:07 AM
Hussler's Avatar
Hussler
If you don't already have it ...
1996 Bronco/F-Series Workshop Manual
Go to section 18 - Lighting then to Trailer Electrical Schematic. Has the diagram and pin outs on the relays and trailer connector.
Old Dec 28, 2012 | 09:29 AM
  #28
Splatts's Avatar
Splatts
Just what I was looking for thanks!!
Old Dec 28, 2012 | 08:39 PM
  #29
Splatts's Avatar
Splatts
Almost got all the wiring in on the trailer. The harness I got at the JY even though its a different part number it still works. I got power at the plug for reverse lights when the truck is running. Thanks for all of your help and advise. I will post up some pics of the trailer reverse lights and my truck reverse lights. Tis the season for lights. Lol
Old Dec 28, 2012 | 08:51 PM
  #30
ReBilld's Avatar
ReBilld
Good job! I think ALL trailers should have back up lights. It's a pain tying to back a long trailer in the dark.
