Polyurethane Cab Mounts Worth it?
Is it worth the $65 or would it be just as good to get some used ones from the junk yard? Mine looked like cracked pancakes and I'm redoing the interior so might as well.
make the ride comfort not as comfortable.
Were you going to get used rubber body mounts? or used polyurethanes
from the JY?
What are you plans for the truck after restoration? DD or weekend use?
What is your time worth as far as pulling parts off of a wreck/donor? (unless
you own the donor).
Generally Iʻll get used parts from the JY if they are obsolete OEM.
If I can get new parts Iʻll buy new, I donʻt like wasting time pulling
off parts from a donor when I can buy new, (almost like doing the
same job twice) and getting off old parts takes a bigger hammer sometimes.
Like many projects there is a "tipping" point for you.
Money vs. time vs. value.
Keep us posted.
you own the donor).
Keep us posted.
Installation was by someone else since I had a cab swap done because of rust.
Old ones were rusted together so an angle grinder was used to cut them apart where necessary.
Much better to buy them new since used ones (were) can be rotted.
Consider buying the set with new bolts - just grind off the old nuts.
You will be very pleased.
I noticed a slightly higher position when driving than before...
Theres alot more to it then just the rubber
If they are that stiff, will it put too much strain on the cab if the frame cannot give as much while trail running? I've popped windshields just by lifting the plow on a truck in the past because of cab flex.
Suggest grade 8 bolts from NAPA the correct lengths and diameter - save any old washers that go under the bolt heads or nuts if needed and reusable.
I think 3 pairs of different bolt lengths would be needed - front cab, rear cab and front clip.
I am sure the mounts move enough to not put a high strain on the cab - a bigger worry was the mount holes on the frame were partly rotted out and could break out in rough trail rides - the mechanic washered this spot to avoid breakage. The pounding on the bolt with a large hammer shattered the mount hole area - which is why I suggest cutting the nuts off... (washers were badly corroded too)
It is possible to get new front mountings if rusted out.
1979 F150 cab Mounts | eBay
It is worth the effort!
If they are that stiff, will it put too much strain on the cab if the frame cannot give as much while trail running? I've popped windshields just by lifting the plow on a truck in the past because of cab flex.The kit I installed only had the poly 'pucks' which had washers and the sleeves embedded into them. There were some (12) washers provided, used under the bolt head and the nut as I recall, since the pucks squash down under the bolt head on top and the nut at the bottom.
The original ones on the truck had sleeves that rusted together so when the nut and bolt were removed the top and bottom sleeves (the top one slid over the other) rusted together and were first pounded on with a heavy hammer - which worked to separate 5/6 of them - but also knocked out a part of the frame mount the rear right cab.
I used an angle grinder to cut the last pair of sleeves off by cutting the top off as seen from on top of the frame then it just fell apart.
The mechanic tightened all quite tight when installing - squeezed to almost no play.
All but 1 of the bolts were used again - however it took a 1/2" power bar with a piece of pipe to remove the nuts after all were soaked in 'Deep Creep'
Order the kit and take the clip off, and the cab loosened, and old mounts off the frame then you will know what to get from NAPA or ACE.
I would anti seize when putting the nuts back on again.
