1979 4x4 highboy?
Old May 25, 2003 | 11:42 PM
1978ironhead's Avatar
1978ironhead
Exclamation 1979 4x4 highboy?
New to this place. Please help me . I got my wife a 1979 ford f150 4x4 and was told it could be a highboy. I've tried to do the vin code but it will only tell me the front half. the code is a follows (f14hneh1246) . any information will be very helpful. Thanks..
Old May 26, 2003 | 08:24 AM
gregdatech's Avatar
gregdatech
1979 4x4 highboy?
Nope sorry, not a highboy. Its an F150, but no such beast. Highhboys were made from 67-77 in f250's and had divorced transfercases. Just got an F150 that sits tall. Cant complain about that!
Old May 26, 2003 | 12:33 PM
Mil1ion's Avatar
Mil1ion
1979 4x4 highboy?
E-mail responded back to Ironhead with this.
My reply in Bold type.
This post is better served on the message boards but here it is.
According to the VIN #
Hello. How are you? My question is as follows. I got my wife a titled 1979 f150 4x4. nobody can tell me anything on the vin. I was told maybe a highboy?
The vin is (F14HNEH1246)
F14 =F150 -4x4
H =351M engine
N= Built at Norfolk Va
EH1246 = Consecutive build code Possibly Mar 1979
3-79 This part of the sticker can verify that
gvwr 6300 lb 2857 kg
Maximum vehicle of vehicle loaded
front gawr 3300 rear gawr 3580 tires 10-15c 15x8.0jj then down on the left side bottom it has f0002 and below it t0456 there is a plate on the door and the information is
F10gnv82305 wb=133 color=m type/gvw=f105 body=2 4 trans=g axle=17j max gvw lbs=05100 dso=25 in the middle of the last two 1975 is stamped. Can you help me? Any information would be greatly apperciated. you e-mail me back at
It looks to me like the Door has been replaced and the rating plate wasn't removed.
They stopped making "Highboys" in 1977
Old May 26, 2003 | 07:17 PM
1978ironhead
Cool 1979 4x4 highboy?
Hey thanks guys. Ijust found out that the door was replaced. But I do have one question remaining. The front axle is a solid axle with one p/s gear box and two p/s assisted rams. and the wierd thing is there are factory holes in the dash in the shape of a d with snow plow stickers on them? Did ford make a speacial truck for just this?
Old Jun 1, 2003 | 10:12 AM
Wild Stallion's Avatar
Wild Stallion
1979 4x4 highboy?
Yours sounds like an emissions exempt '78 I had up to a few years ago, it had a 400, 4.10s, double rams a detroit locker in rear and a posi unit up front, sat up TALL from the factory.
I wish my ex had never talked me into selling it. It was an original Texas Truck, had the big gas filler hole and a sticker on the valve cover that said emission exempt.
Old Jun 1, 2003 | 10:31 AM
tellico racing's Avatar
tellico racing
1979 4x4 highboy?
I have never seen the power assisted ram steering on the F150's, That doesnt mean they didn't use it, I just never saw it. The only trucks I have seen with that on it have been highboys
Does your truck have leaf springs or coils on the front? Is the t-case bolted to the trans or is it set back and coupled to the trans with a driveshaft?
Maybe a previous owner swapped an F150 body on a highboy frame. Can you post a pic?
Broncster72
22
Oct 8, 2020 04:38 PM
riverbedjedd
Dec 29, 2013 01:11 PM
79 highboy
Jun 14, 2013 12:09 AM
Suzukiboy2012
Apr 25, 2012 02:24 PM
blueoval79
15
Oct 4, 2002 09:10 PM
