35's?
Old 12-24-2012, 10:56 PM
4x4fordf150's Avatar
4x4fordf150
4x4fordf150 is offline
35's?
Hey guys i have a 1990 ford f250 no lift and i am in the market for some nice tires. I am just wondering how 35 boggers would fit. What would i have to trim, how bad would i rub, would i need new gearing?
thanks
Old 12-25-2012, 12:13 AM
burnout400m's Avatar
burnout400m
burnout400m is offline
Check the axle code on the door tag to find out the gear ratio. I forget what code is what but just do a search for a door tag decoder. If you have the 3.55 gears you'll probably want to put in a lower ratio, if you have the 4.10s then you're fine.
As for fitting, well my F250 has 265/75r16's now but I have a lot of room to go bigger, 35's might be possible. HOWEVER it looks like someone may have put a body lift in mine at some point. I'm not positive.
If you have a beater truck than you should be able to get your clearance with a sawzall but you may still rub on the frame/suspension. On the other hand ~4" of lift should get you above some 35"s without having to hack on your truck if the body is nice.
corey
05-30-2004 04:47 PM
Garlicbreath
02-14-2004 07:32 AM
Ford4x4435
1997 - 2003 F150
11-11-2003 07:34 PM
texashottie
1978 - 1996 Big Bronco
10-09-2003 11:48 PM
ford_boy4819
06-06-2002 11:20 PM
Quick Reply: 35's?
