1966 - 1977 Early Broncos
c-4 trans filter change help
Old May 25, 2003 | 10:33 PM
jeep232's Avatar
jeep232
Exclamation c-4 trans filter change help
Hello all I am in desperate need of help. I am putting on a new filter in my old c-4 1974 bronco. I didn't know that there would be a spring and stopper fall out. I know where it goes but nut in what order, Does the spring go in first then the stopper and the filter holds it in or the other way around? Any help will be appreciated. Thanks for the help.
Old May 26, 2003 | 08:40 AM
jeep232's Avatar
jeep232
I have looked all over the internet with different searches and can only find two references to the spring and plunger under the filter. This is to control shifts. One of the articles not as a sidebar that he noticed the spring in his catch can and put it in spring first then the plnger then the filter. He said his shifts felt different. No other info was given. I would rather do it right the first time. I hope someone can help out. Thanks.
Old May 29, 2003 | 10:43 PM
RCrawler's Avatar
RCrawler
The plunger goes in first. Large end in first. And then the spring.
Jason
Old May 30, 2003 | 12:08 AM
steve83's Avatar
steve83
http://www.mustangcentral.net/tech/c4/c4exp.gif
http://www.mustangcentral.net/tech/c4.html
Old May 30, 2003 | 05:05 AM
jeep232's Avatar
jeep232
Thumbs up c-4 trans filter change help
Thanks for all the help. I got it put back together and it runs great!!
