Sway bar
Old Dec 22, 2012 | 10:04 AM
Turfzilla's Avatar
Turfzilla
Sway bar
Will a rear sway bar from a 00-05 f -250 fit an excursion?
A friend of mine found one in the pull and pay this morning and wanted to know if in could use it?
Old Dec 22, 2012 | 10:17 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I pulled one off a wrecked F350 and it fit fine. You just have to make sure and get the axle brackets from the wreck. The passenger side bracket on the X has a skid plate that gets in the way, and I had to remove that bracket to get the sway bar on. Also, the end links will likely not be EXACT for the X depending on the lift that was on the F250. I had to buy new end links from Advance to complete the install, as the links on the lifted F350 were too long. I forget what length end links I bought. I mounted the bar on the axle, held it level, and then measured from the hole in the frame down to the bar. Also, the passenger side brake line secured to that skid plate with a little wire thing that had a bolt holding it. I just twisted the little wire mounting gizmo (not as easy as it sounds, but not too hard) and remounted it to the new bracket.
whitesaige
Nov 25, 2017 07:05 PM
Sous
38
May 6, 2016 07:25 PM
LeoJr
Sep 10, 2015 07:54 AM
monster86f250
May 20, 2001 07:17 PM
David
Offroad & 4x4
Apr 5, 2000 06:23 PM
