Sponsored by: Real Truck
Poor acceleration at 50-70mph
Old Dec 22, 2012 | 05:05 AM
Keepitrunnin's Avatar
Keepitrunnin
2001, F250, 5.4, 4X4. Getting on the highway, truck doesn't want to get to speed. Vibrates and downshifts. After about 70, it smooths ouit and runs ? Thanks.ine. Any ideas on where to start
Old Dec 23, 2012 | 09:48 AM
Furian's Avatar
Furian
You Keep What You Kill
Have you checked your transmission fluid? When was it last serviced?
Old Dec 23, 2012 | 04:21 PM
Keepitrunnin
Tranny is due for a change, but the fluid level is good and no burnt smell. It's clean. This started after filling up at a station I don't normally use. It was about 3 tanks ago. I've added some stuff to the gas and injector cleraner, but still the same. I'm going to change the fuel filter next. At slow acceleration, it's OK. After running at 70+, it smooths out and runs fine. It idles fine, so I'm at a bit of a loss.
Old Dec 23, 2012 | 07:11 PM
Bigpipes 35's Avatar
Bigpipes 35
If it seems like it loses power with with higher rpm like if you step on the gas and it down shifts and it seems like you lose speed or power instead of gain I would check the catalytic converter. Thats what was wrong with mine..
Old Dec 23, 2012 | 07:19 PM
Keepitrunnin
Thgose are the symptoms. As I get on the highway, I step on the gas, it downshifts, but doesn't accerate quickly. Than slooowly, gets up to speed. I'll look into the converter. Thanks.
otrawj
Apr 10, 2011 03:47 PM
Bowhica
1997 - 2003 F150
Mar 16, 2011 10:37 AM
shookler
Feb 25, 2007 05:19 AM
gnmano
1978 - 1996 Big Bronco
Jul 11, 2005 08:48 PM
The_X_Family
Apr 13, 2004 06:50 AM
