Hi
i have an 09 F350 XLT with the 6.4 diesel. Im having 2 problems. #1 front hubs dont want to work in auto mode. #2 when i have the heater running and set to the dash vents, it blows out of the passenger vents significantly more than it does the driver side vents. The temperature is the same, just less airflow. i know sometimes vacuum problems can affect both hubs and climate control; just curious if this is still likely since the climate control problem is from side to side. What would other likely problems be? This vehicle does not have dual climate controls for driver and passenger.
