computer error readout with a paper clip?
Old Aug 22, 2002 | 08:19 PM
rhetor's Avatar
rhetor
i read somewhere that you could find error codes using a paper clip and the battery volt meter... i tried searching on the internet but found nothing.
anyone know how to do this?
how much do those little code readers cost anyhow?
thanks in advance!
Old Aug 22, 2002 | 09:16 PM
lghtningstruk's Avatar
lghtningstruk
If its an EEC-iV system check here;
http://dalidesign.com/hbook/eectest.html
This sight explains how to test the EEC-IV system real well - you don't need any special tools - just a jumper wire and count the number of times the check engine light flashes.
Good luck,
Carl
Old Aug 23, 2002 | 11:42 AM
rhetor's Avatar
rhetor
nice thanks carl!
now i can quit being paranoid that for whatever reason my truck has a problem even though it runs perfectly fine!
Old Aug 23, 2002 | 01:02 PM
rhetor's Avatar
rhetor
[updated:LAST EDITED ON 23-Aug-02 AT 02:32 PM (EST)][edit] turns out the voltimeter wasn't working correctly. I couldn't find out why until i read the label on the side of the unit. It said "Radio Shack". Had to resolder the leads on the spikes, then it worked fine! Now i just have to figure out if i'm reading this code right. Thanks, carl, for the link! [edit]
Old Aug 23, 2002 | 03:02 PM
bluechow's Avatar
bluechow
