Swapping wimpy 8.8 to a Dana 60 thoughts?
Old Dec 19, 2012 | 03:56 PM
Diesel_Brad's Avatar
Diesel_Brad
The front is NOT a direct bolt in, you actually have to cut a chunk of the frame out for the front spring hanger/shackle
And NO, the stock F350 will NOT sit as high as your 6" lifted half ton
Old Dec 19, 2012 | 04:25 PM
GNR22's Avatar
GNR22
Oh yeah, I forgot about the front hanger operation there. Are you sure it won't be as tall? His truck only has a 4" lift if I remember right from his build thread. It also has a 3" body lift. So I'm pretty sure it'll be just as tall, if not taller.
Old Dec 19, 2012 | 05:43 PM
firerescue9's Avatar
firerescue9
Okay, ill look into the sas more and not clog up this thread because i want to utilize coils up front instead of leafs for more flex. As for the rear, my truck has quad shocks in the rear, those will be used too? Ill take some pics tomorrow morning.
Old Dec 19, 2012 | 06:03 PM
Puddy's Avatar
Puddy
SAS and coils.... Sounds expensive.
Just get a rsk kit for the front, and stick with leafs.
IMO, just go to a pick and pull, find a 350 or 450 take everything the axles are connected to.
Old Dec 19, 2012 | 06:15 PM
firerescue9
I jus said 3 posts ago im getting a f350 friday, 1990 f350 7.3 std cab long bad. There has to be threads on it and how its done, im positive people do a SAS w/ coils
Old Dec 19, 2012 | 06:16 PM
White 97 xlt's Avatar
White 97 xlt
Somehow I think we are going to see 2 trucks turned to crap before this swap is complete..
Old Dec 19, 2012 | 06:28 PM
GNR22's Avatar
GNR22
If you want to keep coils, get a Dana 44 from a 78 or 79 F150 or Bronco. You'll have to fabricate some stuff, but you can keep your coils without destroying a Dana 60..
SCRebel has an SAS done to his truck with the set up I just described, and will probably know more specifics about that than I do. I have a D44HD from a 78 F250, since I have leaf springs.
Old Dec 19, 2012 | 06:36 PM
Puddy's Avatar
Puddy
TheTinian
151
Mar 27, 2016 02:49 PM
rangernut09011980
May 25, 2015 08:08 AM
godblessmud
Oct 5, 2007 09:12 PM
grmnrkt
Jun 2, 2005 06:14 AM
