Front end vibration
Old Dec 14, 2012 | 09:37 PM
22fordguy's Avatar
22fordguy
Front end vibration
Ok back story. Got stuck in my driveway a few days ago due to deep snow. While rocking the truck to get it free it was bouncing a little bit. After I got the truck out I noticed a slight hum at about 30+ mph from the front but only when 4wd engaged. while pulling out a box truck that was stuck in the snow tonight truck was hopping a little. now I have a vibration to go with a slightly louder hum. only makes the noise with 4wd engaged and hubs locked if i go into 2wd and leave the hubs locked everything is normal. have not tried it with 4wd and hubs unlocked. Thinking possible u joint on front drive shaft but cant notice any play when truck is put in fwd then reverse and back again. 07 f250 6.0 140080 miles.
Old Dec 14, 2012 | 10:54 PM
BLADE35's Avatar
BLADE35
so lets get this straight
Hubs in Lock still in 2wd everything OK
Then Hubs in Lock and switched to 4X4 Noise and Vibration
So when the Hubs are in Lock Everything from the driveline to the Hubs Spins
to check the Ujoint at the steering knuckles you have to turn fulley right and left and Spin note any Play/Drag/Bind
Old Dec 14, 2012 | 11:12 PM
22fordguy's Avatar
22fordguy
Have not tried this as its -20 today. had truck on the jack yesterday when it started and didnt notice any issues in the front end but i also didt turn the wheels and try turning. This would be alot easier to do if the truck easily fit in the garage.
Old Dec 14, 2012 | 11:19 PM
Papa Tiger's Avatar
Papa Tiger
Might th e tires have become dissimilar size due to wear on the tread, especially agressive treads. Also on a partially hard dry surface. Those cold tires?
Old Dec 14, 2012 | 11:24 PM
22fordguy's Avatar
22fordguy
Had new tires put on July 1st right before i came up here form Colorado. do not notice any uneven wear on them. Definatly not an aggresive tire. Just a good A/T. And as far as cold it dosnt matter if its the first drive in the mornig or after I have been in the truck for a while.
Old Dec 14, 2012 | 11:37 PM
BLADE35's Avatar
BLADE35
To test those 2 front Ujoints at steering knuckle truck on ground (No Jack) Hubs UNLOCKED Turned right and Spin Noting How it Moves turn left same thing
you just are making the bearing Fulley Move in the ujoints
Old Dec 15, 2012 | 12:29 AM
22fordguy's Avatar
22fordguy
oh got ya thought you wanted hubs and all to spin. also few things i forgot to post earlier is it only does it while pressing the gas if im just coasting all is fine. And on a side note is there anything wrong with keeping the hubs locked at all times even if in 2wd.
Old Dec 15, 2012 | 01:23 AM
BLADE35's Avatar
BLADE35
Ya dont need Hubs Locked to check Front U-Joints at steering knuckle
Spining the Axel when turn right and left Makes the U-Joint bearings go threw a Full Range Motion
MPG will drop
Old Dec 15, 2012 | 01:45 AM
BLADE35's Avatar
BLADE35
1. Ok only makes the noise with 4wd engaged and hubs locked
2. if i go into 2wd and leave the hubs locked everything is normal.
The only thing that changed here^^^was the Transfer case being engauged
with the hubs Locked in Both senereos 1 & 2 everything was spining wheels hubs ujoints driveline. The only thing that changed was the Transfer Case
makes me wonder about the transfer case
Hard to say this side of the computer
When Hubs Locked and in 4x4 these trucks will kinda Hop when turning on dry pavement IDK the exact senereo you had
Old Dec 15, 2012 | 10:44 AM
tiredlr's Avatar
tiredlr
Checked your front driveline U-Joints?
Old Dec 15, 2012 | 08:00 PM
Papa Tiger's Avatar
Papa Tiger
I would look close for metal on metal inner brake pad/ frozen caliper piston.
Old Dec 16, 2012 | 12:50 AM
22fordguy's Avatar
22fordguy
Ok so dissasembled the front drive shaft today to do the u-joints had no idea there was a ball joint in there. hardest set of u-joints i have ever done.
Old Dec 16, 2012 | 11:40 AM
BLADE35's Avatar
BLADE35
so the u-joints were Bad???
These Balljoints can be a BEAR if everything is rusted together
Old Dec 16, 2012 | 12:01 PM
22fordguy's Avatar
22fordguy
Dont think the u joints were the problem. But the ball joint in the cardon joint was toast so possibly that. About to put every thing back on so I will update.
Old Dec 16, 2012 | 01:17 PM
22fordguy's Avatar
22fordguy
So all is good just finished the test drive no noise or unnatural vibrations. As I said earlier the u-joints seemed fine but the ball joint in the drive shaft at the transfer case end was gone. no one in town listed a part number for a rebuild on this so I got Orielys to let me flip thru the precision u-joint book. The rebuild for the 99-04 is the same part(there are two different ones listed assuming one was for the 7.3 and the other the 6.0) part number for the ball joint is 617 (precision part number) and all three of the u-joints are 232 (this is the HD greasable there are also non greasable but dont have the number for those)/
