ESOF Compressor?
Old Dec 14, 2012 | 12:07 PM
Big Sky's Avatar
Big Sky
ESOF Compressor?
OK-Here is my question. When I turn the key on my Excursion, I hear like a compressor kick in. I am assuming that is the pump that helps operate the ESOF to where I don't need to turn the hubs in. The problem is that it doesn't always come on and have had to manually turn the hubs in for 4WD. Is failure of that pump common or is there a relay that controls that?
Old Dec 14, 2012 | 12:11 PM
That_Guy's Avatar
That_Guy
Does your heat/ac only blow out of defrost?
alot of times there is a cracked vacuum line somewhere.
Old Dec 14, 2012 | 12:50 PM
woodnthings's Avatar
woodnthings
The hubs work off of the vacuum pump. Take at the fuses and see. Most likely like mentioned in the above post, you have bad vacuum lines.
Cryptmaster
Oct 8, 2017 07:37 PM
hpcbmw
Sep 16, 2016 12:22 PM
deputydog03
Nov 13, 2015 05:23 PM
DGMFORD
Jan 7, 2010 12:31 AM
dmueller71
16
Dec 17, 2009 07:44 PM
