Been awhile... 79' Mud Bogger
It will be done for the next season. Crap at the local track I was a partner in running made it so I just didn't have the ambition to fix it. Now that I'm going back just as a racer, it will be done. Might see me down there early when your season starts to do some shakedown runs
lol aight, I plan on swapping tran's this winter, and junking the Hub's and replacing either with a brand new set or going with flanges. also looking into taking a little weight out of the truck, Id love to fix up my brake's like you did, but not sure if i will or not. but getting away from the steel wheel's and all. Id love to come across some uncut 38 skinny's for my front end aswell. BTW The Doo open's up Feb 2nd. guess i better get to work gotta lot of stuff to get done between the Ford and the Jeep, BTW You aint got a extra driver side door for 73-79 do you?
If you ever get it done.... there's been some guy's from elizabeth city coming down lately that run pretty good.
there was a silver Chevy that came down from i think he said Chesapeake this weekend called "goin-n-deep" thing was pretty bad, but i think i could of played had second gear not been slipping on me, then on my first pass in B heavy the dang front end popped a hub again.... but still pulled out a 16 second pass when the last 50-60 feet was in 2wd
I'm real slack on decent 79 body parts. Kris may be your best bet for the door. Don't know if I'll be done by Feb, but will start work in January on doing what I need to get done. Should have everything done by mid March though.
I still don't understand why you keep breaking hubs unless you are using old ones you found somewhere. I swapped on a set of Superwinch Premium hubs 4 years ago and haven't had a problem with them. You need to get the premiums with the metal internals. The standard Warn and similar have plastic part that break.
no it's well past my hub's deep, I stuck it the first pass and didnt pull the cable so had to get out to hook it up. needless to say it was up over my hitch and it was digging in the mud and when i opened the door it was pushing mud. I went over knee deep in it pretty close to hit deep and i stand about 6'2
Finally got the truck back, and man does it sound and act like a whole different beast. Hopefully I'll get time this weekend to post a video or something up, and I got the info for the cam they put in. It's still all greek to me
http://sphotos-b.xx.fbcdn.net/hphoto...42572967_n.jpg
NMFirstF2504X4
26
Apr 30, 2015 11:51 PM
Indecl
26
Mar 28, 2012 02:22 PM
USArmyTaterness
Mar 6, 2012 10:23 AM
