VIAIR 10009 Installed
Old Dec 16, 2012 | 09:23 PM
marchare011's Avatar
marchare011
Nice install Randy.
I like your attention to detail.
Old Dec 16, 2012 | 10:42 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
That's a nice job Randy
Old Dec 17, 2012 | 06:54 AM
ruschejj's Avatar
ruschejj
I love the VIAIR products.
You have the same issue I do though, the water drain on the tank is not functional. I've been running my system for two years and have not drained the water out yet. I really need to do that....
Old Dec 17, 2012 | 12:06 PM
my996duc1's Avatar
my996duc1
I try to remember to drain mine when I drain the water seperator.
I have never seen water out of the water seperator but I always get water out of the air tank.
_
Old Dec 18, 2012 | 07:11 PM
Maineman2011's Avatar
Maineman2011
I installed mine inside the Urea tank casing that is no longer needed..
Old Dec 18, 2012 | 07:18 PM
Maineman2011
Here's another view with the tank mounted to a body channel.
Old Dec 19, 2012 | 09:23 AM
porthole's Avatar
porthole
_
I added pull cable drains to both tanks. Making it easy means you will do it more often.
Old Dec 20, 2012 | 01:18 PM
dixoncity's Avatar
dixoncity
How did you secure the loose end of the pull cable? Nice work.
Old Dec 20, 2012 | 02:01 PM
porthole's Avatar
porthole
Both cable ends are just pinched under a bolt/washer. The cable under the bolt in the picture is for the tank above the driveshaft. That tank never gets water, but I still like to check.
Old Dec 20, 2012 | 07:31 PM
uscgmkcret03's Avatar
uscgmkcret03
Porthole
Did you make the U Bolts holding the tank on or purchase them, Thats a great idea, I like the idea of not drilling into the frame.
Old Dec 20, 2012 | 08:54 PM
porthole's Avatar
porthole
Those u-bolts came with the tank, but I have made and or purchased large U's like that in the past.
McMaster Carr is a distributor that has carried u-bolts like that.
Old Jan 2, 2013 | 05:14 PM
dixoncity's Avatar
dixoncity
I just got the Viair system for Xmas. The manual says the compressor is water and dust resistant, NOT WATER PROOF OR DUST PROOF. So, I'm thinking of trying to install the compressor in the cab, behind the rear seat. The only limitation seems to be the 2 ft leader hose from the compressor to the tank. Anybody give this a try? And if not, have you done anything extra to protect the compressor mounted under the vehicle? Thanks in advance, Jim
Old Jan 2, 2013 | 05:28 PM
  #28
ruschejj's Avatar
ruschejj
My compressor has been 100% out of sight out of mind under the truck for over 2 years and 138,000 miles. It holds up just fine under there as long as you don't find a way to mount it right behind a tire or something. Stuff under there actually stays pretty dry.
Old Mar 22, 2013 | 12:24 PM
  #29
dixoncity's Avatar
dixoncity
Anybody have issues with the tank bleeding down because of small leaks? If you don't have any leaks, did you do anything special to stop them? My system has been installed for a couple of weeks now, but is suffers from leaking.
Thanks, Jim
Old Mar 22, 2013 | 01:59 PM
  #30
SavageNFS's Avatar
SavageNFS
Find the leak (soapy water works for me) and fix the leak. A lot of them are as simple as remove the line, clean cut it and reinsert and leak is gone. Threaded connections need Teflon tape or plumbers paste.
