Originally posted by DaveBey 2003 F-150 - CLOCK ADJUSTMENT PROCEDURE FOR DUAL MEDIA RADIO - OWNER GUIDE UPDATE
SOME 2003 F-150 VEHICLES EQUIPPED WITH THE DUAL MEDIA RADIO MAY NOT CONTAIN THE CORRECT PROCEDURE IN THE OWNER'S GUIDE FOR SETTING THE CLOCK. TO SET THE CLOCK: PRESS THE 'CLK' CONTROL UNTIL 'SELECT HOUR' IS DISPLAYED THEN PRESS 'SEL <' TO DECREASE THE HOURS OR '>' TO INCREASE THE HOURS. TO SET THE MINUTE, PRESS 'CLK' CONTROL UNTIL 'SELECT MIN' IS DISPLAYED THEN PRESS 'SEL <' TO DECREAE THE MINUTES OR '>' TO INCREASE THE MINUTES.
Cheers from Tulsa, OK!
Dave
I need some help in figuring out how to make the 2003 Explorer XLS AM/FM/Cass/CD radio display the time on the clock all the time. Everytime I start the vehicle, the radio channel displays and never automatically switches back to the clock - at least until you punch the clock button then radio changes will momentarily display the channel then flip to clock. This is wierd. Can't find anything in the manual about this issue. THANKS!!!
