Trailer keeps blowing lights?
Old May 24, 2003 | 05:10 PM
sportscar's Avatar
sportscar
Seems like every time I hook up my flat car trailer, the rear lights blow. Does this sound like a bad ground?
The trailer is now a few years old with only a few thousand miles. Any suggestion on what to do as far as routine service.
Thanks
Old May 24, 2003 | 06:13 PM
Colossus's Avatar
Colossus
First of all, I am not a wiring expert, but I have worked with car trailers before. Your problem could be caused by any number of things, including the ground. I have never worked with this particular problem before. On my trailer I had a side marker light short out and all of the trailer lights would not work properly. The way to solve this problem would be to buy an electrical tester - the kind with the light - to see where you have power and where you don't.
Old May 25, 2003 | 02:25 PM
ckrichard's Avatar
ckrichard
Are you talking about the bulb of the fuse blowing. If it is the fuse check to make sure there are not any cuts in the sheething around the wire, this could be causing a short.
Chris
Old May 25, 2003 | 06:45 PM
sportscar's Avatar
sportscar
Originally posted by ckrichard
Are you talking about the bulb of the fuse blowing. Chris
Tail/stop and/or side markers blow .... bulb is blackend.
Steve
Old May 25, 2003 | 09:41 PM
ckrichard's Avatar
ckrichard
It sounds like you have the wrong bulb for the trailer. You probily want to try a bulb that is rated for a higher amount of power.
Chris
kruzer
All Things Towing
13
Sep 6, 2012 08:35 PM
fireeater91
Jul 20, 2012 09:39 PM
MobeyDick
All Things Towing
Nov 13, 2011 11:44 AM
767indian
Aug 16, 2010 09:53 PM
Zirk
1983 - 2012 Ranger & B-Series
Jan 21, 2009 10:19 PM
