Average cruise speed??
Old Dec 13, 2012 | 08:16 AM
Deer545's Avatar
Deer545
Thanks again everyone. I learn more information everytime I look on this site. So it sounds like 65-70 should be top speeds for cruising on the highway.
Old Dec 13, 2012 | 11:33 AM
Ken Blythen's Avatar
Ken Blythen
You can always put some bigger diameter tires on the rear for these trips.
I don't know what you have now, but if they are 28", then going to 31" (just an example) will reduce the engine revs by approx 270 rpm. @ 75mph.
Naturally, you will lose some performance.
Old Dec 13, 2012 | 12:21 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by Gary Lewis
Yup. Oddly enough, people say that Ford spent a ton in the wind tunnel on the aerodynamics of these trucks. In fact, Wikipedia says "the exterior of the trucks was redone to improve aerodynamics and fuel economy." If Ford spent a ton they either didn't get their money's worth or were just checking to see that the remit they gave the designers was followed - make it like a brick.
If you look at the 1973, compared to the 1980, you can see they attempted to make an improvement.
Some of these are:
1: The Drip Rails don't wrap around the back of the door causing drag.
2: The front section of the 1980 is angled at both sides instead of totally flat like the 1973-1979... ( /---\ compared to ---- )
3: The slope of the windshield is a little less inclined...
4: ... hmmm....
So they at least tried to make improvements...
Myth Busters did a segment on the tailgate, and busted that myth. Best to run with it up.
Ah yes the Air pillow that is formed with the tailgate up, so air will glide off the cab over the tailgate. The same air pillow that causes air to be forced into the cab with the rear slider window open. If the tailgate is left down, the air pillow doesn't form, and air is redirected hard into the down tailgate creating drag. So would that be 4 on that list, or just good luck on the design? Mythbusters proved it with wind tunnels so...
I do see where they tried to make improvements in areodynamics, however it's very primitive to let's say a 2013 F-150. Whether they succeeded or not, or if they didn't change certain things because of lack of technology, or because of fear of consumer backlash is debatable.
I do remember stories/rumors that Ford was worried that the 1980 may be too different to the 1979 and people wouldn't buy. After all if you were a farmer in 1979 looking for a new pickup, and the 1980 was designed like the 2013, you would probably say, what the $%^& is this spaceship looking thing?
Old Apr 19, 2013 | 07:40 PM
Pbrvic0127's Avatar
Pbrvic0127
Originally Posted by Deer545
I have a 1986 300 I6 all stock. Has 3 speed C6 trans with 3.08 rear end. I never drive it over 65. I just feel the truck is older and why beat on it, everything works perfect. My question is was the truck designed to cruise at 70 on the interstate for long distances. This will be the first year I'm taking the truck for a few 300 mile trips pulling a 2,000-2,800 pound trailer loaded. The other trucks going with are newer and will be cruising 70-75. I'm concerned the rear end and 3 speed trans were not designed for these speeds. Pulling a trailer or just driving down the interstate should I be worried driving this fast? The truck is mechanically in perfect condition85,000 original miles and rust free body. I have replaced all most every normal maintenance part on the truck. Fuel pump, ball joints, brakes, belts, cap wires, tires, shocks......etc only part I'm looking into getting is a trans cooler for pulling the trailer, but I don't think I would need one if I was not pulling a trailer over 2,000 pounds.
ill give you a trans cooler next time I see ya. I have two brand new ones in the box
Old Apr 19, 2013 | 09:31 PM
oneowner83's Avatar
oneowner83
I guess its fair to say Ford made incremental changes...don't wanna scare people away with big changes. The biggest effort to increase fuel mileage had to be offering the 4 sp overdrive with the extra-load higher pressure tires. That combination with the 300 has me turning just 1600 rpm at 60 mph and getting 22 mpg....a sweet package. For those who are critical of the lower power in 4th, may I suggest putting it in 3rd....it's 1:1 ratio.
jfralph
6.7L Power Stroke Diesel
Sep 12, 2016 10:30 AM
rashdabull09
Mar 2, 2013 01:55 PM
BarnieTrk
Sep 28, 2010 09:05 AM
Milwaukee1979F150
Dec 2, 2009 09:45 AM
Drone Leader
General Diesel Discussion
Nov 10, 2006 07:06 PM
