2001 Ford Expedition
Old Dec 12, 2012 | 12:42 AM
mkrush's Avatar
mkrush
Hello I Have A 2001 Ford Expedition & When I Accelerate The Car Really Doesn't Want To Put In Power . I Already Changed All Spark Plugs And Coil & Still Don't Know What's The Problem.
Old Dec 12, 2012 | 08:52 AM
pdqford's Avatar
pdqford
Is the check engine light on?
Old Dec 12, 2012 | 09:49 AM
mkrush's Avatar
mkrush
Yes it is.
Old Dec 12, 2012 | 11:04 AM
lv2race's Avatar
lv2race
What are your codes?
Old Dec 12, 2012 | 02:17 PM
mkrush's Avatar
mkrush
Po174 , po306, po308, po401 pd
mkrush's Avatar
mkrush
Old Dec 12, 2012 | 05:21 PM
alloro's Avatar
alloro
Cylinders 6 and 8 are misfiring.
Old Dec 13, 2012 | 01:30 PM
hodges710's Avatar
hodges710
and running lean
Old Dec 13, 2012 | 04:21 PM
pdqford's Avatar
pdqford
Originally Posted by hodges710
and running lean
Actually, it will be running rich.
Here's my take on what's happening: The misfire is causing "un-used" oxygen to pass by the HO2S. The HO2S reports this excess oxygen to the PCM. The PCM trys to "fix" it by increasing the injector on-time on Bank 2. When the PCM drives the fuel trims to > 30% and it still sees "unused" oxygen from the misfires it says "sumptin is not right" and sets the P0174 code (which means it is driving the injectors on that bank way more than it should and it still sees unused oxygen, which is interpreted as "Lean".)
If the OP has been driving this vehicle like this for some time the other two cylinders on that bank are drowning in fuel and have probaly carbon/coked up the DPFE tubes and/or the EGR passages in the intake. If the PCM doesn't see enough difference between the pressure on each side of the DPFE, it sets the P0401 - insufficent EGR flow.
Old Dec 22, 2012 | 03:35 PM
HjalmarOrn's Avatar
HjalmarOrn
And how do you fix this?
Old Dec 22, 2012 | 09:11 PM
pdqford's Avatar
pdqford
Fix the misfires and clean out the EGR passages.
Old Dec 23, 2012 | 10:24 AM
Moto Mel's Avatar
Moto Mel
The very first thing to do is check your vacuum lines and elbows as well as the PCV itself. It seems that an awful lot of the lean conditions and mifiring problems are caused by the 90* degree elbow at the intake manifold. A vacuum gage would be a help in this case for diagnosis.
IB Cristina
Newsletter Archive
Jul 7, 2017 05:15 PM
BiggyE
May 12, 2016 02:37 PM
cleaningbug94
Nov 29, 2010 08:37 PM
char1746
Jan 22, 2004 01:04 AM
