Starting issues.
Old Dec 11, 2012 | 07:09 PM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
Post Starting issues.
I have a 2005 F-250 6.0. I just had the oil and filters changed as well as the fuel filters. I have had the truck for three weeks now with no problems. Tonight while starting the truck it would idle very slowly and rough. When you put it in gear the truck would stall. It would do this three or four times before it would idle "normally" and could be driven. When driving I noticed the throttle was not very responsive. After stepping on throttle it seemed there was a brief delay before the truck would go and it almost feels like when turbo kicks in/power surges. Any help/info? I have appointment in morning at local dealership.
There is no smoke black,white, grey or other when I do start it.
Old Dec 11, 2012 | 07:24 PM
mustang_309's Avatar
mustang_309
Do you have any gauges like scan gauges II or the like? They are instrumental I diagnosing problems with these trucks. Your issue could be caused by any number of things from HPO leak to FICM so you need something that gives hard data and can read codes
Old Dec 11, 2012 | 07:34 PM
Stroker 6.0 fan
No scan gauge, just got truck and new to diesel and 6.0's. Guess I'll be getting one after tomorrow.
Old Dec 11, 2012 | 07:42 PM
BLADE35's Avatar
BLADE35
go unplug the ICP sensor connector in passenger side valve cover check if oil on it and see if Idel smooths out when unpluged
Old Dec 11, 2012 | 08:54 PM
mustang_309
Sorry for typing broken English but I was responding from my "smart" phone
Old Dec 11, 2012 | 09:05 PM
steelhead2's Avatar
steelhead2
Were oem filters used?. If you just had fuel and oil filters changed and now you have the problem sounds like you should look at them.
Old Dec 11, 2012 | 09:32 PM
Stroker 6.0 fan
They were both done at my local Ford dealership so, I assume they used Motorcraft filters.
Old Dec 20, 2012 | 10:15 PM
Stroker 6.0 fan
My local dealership hooked truck up computer and every test came out fine. They were not sure what was causing it. I bought some fuel additive with citine boost. Have not had any issues since???
rhillman75
Aug 20, 2017 11:37 AM
ramirez7589
Jun 22, 2015 08:31 AM
CrewCabLongbox
26
Aug 11, 2014 02:24 PM
f350project
Dec 2, 2012 08:58 PM
hightech
May 16, 2003 07:12 PM
