The tailgate that came on my truck was in very bad shape, would not close, plus the latch was shot. What other years of tailgates would interchange with My '80?
Later models can be modified, but I believe 1980 and 1981 will just bolt on [perhaps 1982?]. The earlier models used metal support straps and the later ones had plastic coated cables, so the hardware is different.
IIRC 80-86 have the same hinge and latch styles, with only minor differences in the support straps as described above. 87-96 tailgates look similar on the outside, but have very different hinges and latches, so they're not compatible
1980-1982 is a direct swap. E0TZ-9940700-A: Use with Metal Support Arms
1983-1986 will need to be modified to work. E3TZ-9940700-A or E5TZ-9940700-A: Use with support cables. The tailgate would need to be drilled and cut to accept the 1980-1982 hardware, or new 1983-1985 latches installed. The 1980-1982 metal support arms are a part of the latch assymblies.
Two different handles...
E0TZ or E5TZ-9943400-A: Argent 1980-1986
E0TZ or E5TZ-9943400-B: Chrome 1980-1986
There are the aftermarket variety that fits 1980-1986, but they are not that great, and I'd stay away from those.
Thanks for the info.Main thing wrong with the one that was on My truck, it would not close fully, seemed to be hitting the catches on the bed,but not engaging them
its possible that the bed itself is bent in our out on one side and just needs to get tweaked - or its possible that the latch is messed up - but check alignment first and tweak the bed as necessary
Yep, I tried that several times, so after a few 4 letter words I just decided to run with out a tailgate temporarily till I can fix the problem (I don't haul much so will be ok for now)
keep in mind, that running without a tailgate on a "structurally weakened" (AKA rusty) bed can actually cause the bed sides to tweak over time... i did it once...
The latches on the tailgate are adjustable, as well as the catches on the bed.
Found out the problem, the latch rod clips on the tailgate handle were missing. I removed the handle, and then pulled each latch rod, and it is now closed. Where can I get the latch rod clips?
Ford dealer or "HELP" section at most part stores. They are about $1.00 - 2.00 each.
Will check the local O' Reilly and Auto Zone, maybe the NAPA store here. Our Local Ford dealer shut it's doors this summer. If I go to a Ford dealer, what part number, and description of these clips do I use
