Sponsored by: Real Truck
e350 - No heat
Old Dec 11, 2012 | 12:42 AM
danibf's Avatar
danibf
e350 - No heat
I recently replaced the blower motor and resistor as well as the heat relay (which was blown) on the power distribution panel. It all seemed good but I can not get it to heat up. If blows out hot air when the selector is on heat, but it maybe only gets as hot as the engine, not really enough to do much. What else could be the problem?
Old Dec 11, 2012 | 01:06 AM
jh818's Avatar
jh818
Not sure if yours is like my '02 V10, but there is a vacuum activated shut off valve that blocks the flow of coolant to the heater core when you have max AC on. Could this valve be stuck?
Nico80
Nov 24, 2018 05:08 AM
ClassicFordFan95
May 21, 2015 01:09 PM
tommyl
22
Oct 11, 2010 02:50 PM
slowcoupe
1997 - 2003 F150
Dec 12, 2009 06:37 PM
idenchopper
Aerostar
Apr 16, 2004 08:02 AM
