smoking
Old Aug 25, 2002 | 08:29 AM
geoda's Avatar
geoda
smoking
My truck is a 1993,f150,302,aod tranny,2x2,flowmaster exhaust,On the way home it started to put out clouds of white smoke,so thick that you could not see behind you.the engine only has about 5000 miles on it . What do you think I did to it
Old Aug 25, 2002 | 01:33 PM
Redneckerson's Avatar
Redneckerson
smoking
Well it doesn't sound good. White smoke is water so- maybe a blown head gasket? Check the oil and see if there is any water in it. Good luck. RSH
Old Aug 25, 2002 | 06:00 PM
cparks's Avatar
cparks
smoking
Yep, that certainly is from the cooling system. You don't want to drive it to much like this as it is bad on the oxygen sensor and if it does get into the oil, you can hurt the bottom end of the motor. Most likely caused by a bad head gasket.
Old Aug 26, 2002 | 01:37 PM
mayerst's Avatar
mayerst
smoking
Check and make sure the transmission modulator is not pumping tranny fluid into the intake. Does the smoke dissapate quickly or does it linger for a time? If it stays in the air for some time it can be trans fluid.
Tom
Old Aug 26, 2002 | 04:50 PM
geoda's Avatar
geoda
smoking
Took the truck to the shop today , it is definatly a head gasket,will take about 3 days to fix,only $950. Thank to all for the advice
Old Aug 26, 2002 | 04:56 PM
Drexx's Avatar
Drexx
smoking
