IDI PROBLEMS
Old Dec 9, 2012 | 08:35 PM
LoganIDI's Avatar
LoganIDI
IDI PROBLEMS
I have a 1992 7.3 IDI 5 speed manual. When I am driving down the road normally not accelerating or decelerating it dies.. Just shuts off.. It also idles up and down while driving.. I have no idea what this could be.. Any help would be appreciated! I'm new to all this
Old Dec 9, 2012 | 08:58 PM
kla94's Avatar
kla94
Check to see if you have water in your fuel filter.
Old Dec 9, 2012 | 09:09 PM
LoganIDI's Avatar
LoganIDI
Oh yeah I int think about that.. But someone else said something about maybe a sticky governor .. What do you think about that?
Old Dec 9, 2012 | 09:18 PM
1989f250IDI's Avatar
1989f250IDI
U might have an air leak in your lines. Also run a tank of diesel keen
Old Dec 9, 2012 | 09:20 PM
LoganIDI's Avatar
LoganIDI
Ok I mean is this common in the IDI's?
Old Dec 9, 2012 | 09:21 PM
1989f250IDI
An erratic idle normally means ip lines or air intrusion. Check to see if any injection lines or investors are leaking. Also if u have the stock return line it probably needs maintenance
Old Dec 9, 2012 | 09:28 PM
LoganIDI's Avatar
LoganIDI
Ok thanks helps alot
Old Dec 9, 2012 | 09:34 PM
kla94's Avatar
kla94
Mine done the same thing. It would idle up then down to normal. It didn't die, but it did hesitate and acted like it was starving for fuel. Took my fuel filter off and the water in fuel wire was broken inside the elbow at the bottom of the filter. When I took the elbow lose, the metal stayed on the pin in the filter housing. Had water in the bottom but my light never came on. Changed the filter and put a new elbow on the wire. Filled the new filter with automatic trans fluid(every filter change)ran great.
Old Dec 9, 2012 | 09:44 PM
LoganIDI's Avatar
LoganIDI
Alright man sounds like a plan.. Thank ya
Old Dec 9, 2012 | 09:59 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
our most common issues are inexpensive if not free fixes,yet frustrating fuel delivery issues."air intrusion."
if an idi doesn't like to start,start then stalls,misses,shakes with power surges while gown the road,start with inspecting fuel delivery.
Old Dec 9, 2012 | 10:02 PM
kla94's Avatar
kla94
Your welcome. What you described sounds exactly like what happened to my truck. Might be like 1989f250idi said, air. Look for leaks. Most likely not the governor.
Old Dec 10, 2012 | 07:26 AM
LoganIDI's Avatar
LoganIDI
Alright what's the best way to check for those leakes?
Old Dec 10, 2012 | 11:08 AM
kla94's Avatar
kla94
Look for wet spots.
Old Dec 10, 2012 | 02:54 PM
LoganIDI's Avatar
LoganIDI
Alright it's just weird because it doesn't do it all the time
Old Dec 10, 2012 | 03:50 PM
hookedondiesel's Avatar
hookedondiesel
Originally Posted by kla94
Look for wet spots.
, should he try flour...LOL
