203 T-Stat ?
Old Dec 10, 2012 | 11:38 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Speaking of RTV, this stuff works well, slather it on: Permatex/3.35 oz. (95 g.) tube Ultra Black maximum oil resistance RTV silicone gasket maker (82180) | RTV Adhesive | AutoZone.com
Old Dec 10, 2012 | 12:17 PM
SkySkiJason's Avatar
SkySkiJason
I've been running Bob's 203* t-stat for 250k miles in my F350 and over 100k in the X. I would not put much stock in this mod increasing MPG more than changing your driving habits can...
Yes, the heater gets hotter - and faster with the 203* 'stat. I have a ball valve on my heater core supply and CLOSE it in summer for coooold AC.
The reason the billet housing can leak is because it is 100% FLAT - the cast water pump is often not. The flimsy stock housing is more forgiving to imperfections in the water pump. I've had a couple water pumps on each of my PSD's and some worked with just Bob's o-ring and some needed RTV to seal.
Old Dec 10, 2012 | 02:54 PM
2000ca250's Avatar
2000ca250
I will say one thing...after running the 203* for the last 2 years, I am going to go to the 180* t stat. I'm running dual terminator pumps, and my oil temps are a little high for my taste with the 203*. However I did love it with the stock HPOP. Faster Warm up, and seemed to be a bit better mileage. Like .2-.5 maybe 1.
Old Dec 10, 2012 | 03:58 PM
Toreador_Diesel
That's exactly why Joey developed it
Old Dec 10, 2012 | 04:34 PM
SkySkiJason
I have heard that before. What EOT's are you seeing and what conditions?
Old Dec 10, 2012 | 08:31 PM
2000ca250's Avatar
2000ca250
Cruising empty I've seen as high as 220...normally sits around 214. I hear a noticeable difference in the engine when the oil temps get around 210, might be something that can be changed with tuning, might not. Either way, I'm going to swap them out and see if things change. If not then I'll take a look into my tuning and see if its there. I love the heat, but on long trips I feel like its getting the engine too hot with the dual pumps.
Old Dec 10, 2012 | 09:42 PM
Andy's Beast's Avatar
Andy's Beast
The heat works much better. It might run quieter or my hearing is getting worse. Towing in 80T, I was seeing between 210 and 217 for oil temps. I also have a leak that is from the billet housing. I am going to try the Dorman gasket. Are you guys using RTV with the new Dorman gasket?
Old Dec 10, 2012 | 10:19 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I did not have to use RTV with the Dorman gasket I got. Sealed tight for me.
Old Dec 12, 2012 | 11:29 AM
Toreador_Diesel
It's sad when the aftermarket imitation parts sometimes have a better design than Ford
Old Dec 12, 2012 | 12:35 PM
hydro man 17's Avatar
hydro man 17
I recently installed the 203* and housing and no issues at all. Seems to be getting a little better MPG but have only one fill to go by. 16.3 around town and filled to the neck, not sure about the previous fill though. No hutch or harpoon yet.
Mike
Old Dec 12, 2012 | 01:07 PM
honeydew's Avatar
honeydew
With 203F stat the EOT on my truck runs as high as 209F cruising unloaded on the highway.
Old Dec 12, 2012 | 02:19 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I just went back to the 195* IH thermo with my new pump, and the wife is already commenting the heater gets going quicker in the morning. Some have already said they have observed this, and now I have, too.
Old Dec 12, 2012 | 02:38 PM
  #28
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I don't think Dorman is doing anything special besides cutting the gasket thicker...and they are probably doing that by accident!
Old Dec 12, 2012 | 08:01 PM
  #29
Supercab's Avatar
Supercab
Is there a part number for the Dorman gasket/seal?
Old Dec 12, 2012 | 08:11 PM
  #30
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
No idea. It was $2.50 at Advance.
