HELP!
Old Dec 8, 2012 | 07:44 PM
'06Roush_150's Avatar
'06Roush_150
HELP!
First off its a 2006 F150 king ranch with the intercooled roush kit and roush tune. Last couple weeks its progressed from a slight stumble on start up, to now after its been off for a few hours it may start and run rough for a second, or, it may start then die, and then have to crank for at least 5 seconds before it starts. After it starts it seems to run fine.I've thrown the P0172 and P0175 code a few times. I downloaded the torque android app and did some data logging. Can you learn anything from the long term fuel trim? Any help is appreciated.
Old Dec 9, 2012 | 11:23 AM
'06Roush_150
Anyone?
Old Dec 10, 2012 | 02:46 PM
'06Roush_150
If my LTFT stays in the negatives is that bad? And what does it mean? It ranges anywhere from -15% to -30%, never going positive on either bank.
Old Dec 10, 2012 | 04:07 PM
danorules's Avatar
danorules
It sounds like the fuel pump is on its way out and leaning out the motor. 15-30% below the needed fuel is not good
Old Dec 10, 2012 | 04:14 PM
'06Roush_150
If I'm not mistaken, the negative LTFT means that the computer is cutting that much fuel because it has detected a rich condition, hence the P0172 and P0175 codes. Am I correct?
Old Dec 10, 2012 | 07:11 PM
'06Roush_150
Thanks guys....I really appreciate all the help (sarcasm). I fixed it anyways.
Old Dec 10, 2012 | 07:53 PM
danorules's Avatar
danorules
so what did you do to fix this problem?
clearly we couldn't help, so why not post up the repair to help the next guy in your predicamint.
Old Dec 10, 2012 | 08:25 PM
'06Roush_150
You would never guess, or at least I didnt. Went to start the truck after work and the battery was dead,the temperature was in the teens to low 20's all day, and the battery looks like the original from 2006 so I jumped it and went and got a new battery. I think that was my problem, fired up quicker than it has since ive owned it and the LTFT's were back to 0 on bath banks. It even seems to run a little stronger. I dont know it the old battery was just to weak to completely burn, the fuel with the supercharger and colder plugs or what.
Old Dec 10, 2012 | 08:39 PM
danorules's Avatar
danorules
These trucks get strange symptoms when the voltage gets low or inconsistent.
Old Dec 10, 2012 | 10:30 PM
Stewart_H's Avatar
Stewart_H
What's painfully obvious to some, is unseen by others.
Very well stated, Dano.
Stewart
white cat
1983 - 2012 Ranger & B-Series
Dec 16, 2013 10:33 AM
crc4x4
Sep 4, 2012 03:25 PM
01kingranchKY
2004 - 2008 F150
Oct 28, 2010 07:55 PM
mbnv992
Jul 24, 2004 02:11 PM
Colin94Supercab4.0
Jan 21, 2004 01:39 PM
