better headlight housing for HID conversion?
Old Dec 10, 2012 | 10:41 AM
aortizexcursion's Avatar
aortizexcursion
I'm one of those that believes if you are going to use HIDs, they should be put in a reflector system that is designed for the characteristics of an HID bulb.
My ideal, non-HID setup would be to upgrade the wiring harness and slap in some Philips Xtreme Power bulbls.
Old Dec 10, 2012 | 11:21 AM
bigwhitetruck01's Avatar
bigwhitetruck01
Right now i'm running with stock '01 light housings with Silverstar Ultras and a relayed harness. They're aimed as well as i can get them and still they don't light the road like my car or the wife's scion. I too believe that HID's should really only be used in projectors or reflectors designed specifically for HID but the Ex is not a daily driver and i can't justify the cost of having Caesar do a bi-xenon retrofit (which would be ideal). BTW, his bi-xenon retro is the s***. I've been running that setup in my WRX for years and it's phenomenal.
Old Dec 10, 2012 | 04:34 PM
aortizexcursion
Get rid of those '01 housings because they're horrible. Replace them with some '02-'04 housings; the improvement was awesome. The headlights that you gave us a link to are probably better than the '01 lenses too but we all know how headlights that are not OEM can be hit or miss. I'm just saying that perhaps you will satisfied with the light output that halogens provide with superior housings.
Old Dec 10, 2012 | 08:50 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i've heard the 02-04 put out alittle better then the 05-07 but i dont know personally.
i do know that the 01-04 headlights have a great cutoff and i aimed them and have not been flashed with any of my excursions with these same headlights and HID kits.
this Ex i have a 55w 8000K kit hi/low kit.
Old Dec 11, 2012 | 09:01 AM
bigwhitetruck01
[QUOTE=AlaskanEx;12582442]i've heard the 02-04 put out alittle better then the 05-07 but i dont know personally.
Do you happen to have any photos of the light pattern against a wall or something like that?
Old Dec 11, 2012 | 09:07 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
not that i can find. when i get back home on sat i can get one though.
Old Dec 11, 2012 | 09:16 AM
bigwhitetruck01
Sounds good, thanks.
Old Dec 13, 2012 | 05:42 PM
bigwhitetruck01
FTW! I decided to bite the bullet and I'm gonna do a retrofit. Only this time i'll be doing all the work myself. I'll be using an aftermarket '02-'04 clear housing and retrofitting this into them: http://shop.lightwerkz.net/Complete-...r-Retrofit-Kit
It should be a nice project to work on. I'll be documenting everything as i go.
BTW, This is a pic of the cutoff from the LightWerkz TSX/FX retrofit on my WRX
Old Dec 14, 2012 | 12:17 AM
HiZ's Avatar
HiZ
Originally Posted by bigwhitetruck01
FTW! I decided to bite the bullet and I'm gonna do a retrofit. Only this time i'll be doing all the work myself. I'll be using an aftermarket '02-'04 clear housing and retrofitting this into them: http:// http://shop.lightwerkz.net/C...r-Retrofit-Kit
Link is dead, try again
I am very interested in this thread
Old Dec 14, 2012 | 02:37 AM
cameeks's Avatar
cameeks
To many http's
Old Dec 14, 2012 | 02:47 AM
cameeks's Avatar
cameeks
What do you do about inspection? I passed every time when I had my DDM Tuner HIDs with the hi/low. Those dont have a high.
Old Dec 14, 2012 | 07:27 AM
bigwhitetruck01
It's a bixenon unit so it has a hood that moves via solenoid to create the effect of a hi/lo setup. If You've ever read Posts about "true bixenon", that's it. Mechanically, it's the same setup that's in my car...however my car got the top-of-the-line oem hid equipment (at the time).
Old Dec 14, 2012 | 07:28 AM
  #28
bigwhitetruck01
Link is repaired.
Old Dec 16, 2012 | 03:45 PM
  #29
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
ok heres the pic, this is low beam. i took a pic of the high beam but with my 4 aux driving lights it makes it hard to see the headlights.
Old Dec 16, 2012 | 04:08 PM
  #30
BroncoRN's Avatar
BroncoRN
I have a 2000. Will 01-04 headlights fit?
